Equipment Failure |
alan.fuller
Newbie Joined: 19 Nov 08 Location: United Kingdom Online Status: Offline Posts: 15 |
Topic: Equipment Failure Posted: 04 Feb 10 at 11:56am |
As it is winter, following on from last years popular survey of Sailing Fitness, I have composed one on Sailing Equipment Failures. |
Phantom 1228
alan.fuller
Post Options Quote Reply Posted: 05 Feb 10 at 11:44am |
So far a good response, so the data is building up........ Although it is a bit scwed toward the classes that I am a member of the class association of, for instance Solo, where very interestingly, but probably not surprising (given the loose rig set up) that they have a disproportionately high amout of bent masts. Unfornutately, I'm not a member of every class association, and many class association forums only allow members to post, e.g. GP14's So, if you have seen this survey and think the results might be more useful with a broader class participation, and you are a member of a class association with an active but closed to members forum - could I respectfully ask that you consider positing a message and a link as above,( or to the Y&Y form thread here, I dont mind either way) Many thanks in anticipation. |
Phantom 1228
