New Posts New Posts RSS Feed: What are Caps?
What are Caps?
ellistine View Drop Down
Post Options Post Options   Quote ellistine Quote  Post ReplyReply Direct Link To This Post Topic: What are Caps?
    Posted: 25 Jun 09 at 4:00pm
I'd assumed that it's just another name for the lowers. Am I wrong?
Smight at BBSC View Drop Down
Post Options Post Options   Quote Smight at BBSC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 09 at 4:03pm
Cap Shrouds are the set of shrouds also called uppers that basically stop the top of the mast bending forward when the kite is up when the head of the kite is further up the mast than the point where the standard shrouds attach eg a mast head kite. But I'm sure there is someone on here with a much better explination.
RS600 988
alstorer View Drop Down
Post Options Post Options   Quote alstorer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 09 at 4:22pm
Properly, cap shrouds go all the way to the mast head, as distinct from upper shrouds, which might only go 9/10s (or less) of the way up, as I understand it.
Al
Post Options Post Options   Quote ellistine Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 09 at 4:36pm
So if you look at this picture;
RS800
The Shrouds meet the mast where the trapeze wires do and
the caps go from the base of the mast, around the spreaders
to the top (or nearly) of the mast?
How are the caps tensioned?
Post Options Post Options   Quote Smight at BBSC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 09 at 5:03pm
The caps on the 800 and most boats just have a purchase system attached to the bottom of the shrouds.
RS600 988
laser193713 View Drop Down
Post Options Post Options   Quote laser193713 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 09 at 5:38pm
Caps control the bend of the top of the mast, on the 800 they are controlled by purchases because they need to be adjusted regularly but on yachts it would be done with standard bottle screws.
Jack Sparrow View Drop Down
Post Options Post Options   Quote Jack Sparrow Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 09 at 6:38pm
There are lots of different ways to rig a mast that allow it to perform in different ways. But essentially Caps on dinghy's are used on boats that have mast head kites. To support the mast from the loads. They also allow you to control the pre-bend and rig reaction for tuning and gust response.
picture link
Post Options Post Options   Quote ellistine Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 09 at 7:20pm
Thanks Jack. A very definitive diagram!
Edited by ellistine
