New Posts New Posts RSS Feed: Wooden tanks repair advice
jamesewanharvey View Drop Down
Post Options Post Options   Quote jamesewanharvey Quote  Post ReplyReply Direct Link To This Post Topic: Wooden tanks repair advice
    Posted: 27 May 08 at 12:18pm
I have broken the the seal on my wooden tanks on the phantom.
Luckilly the break is nowhere near any of the hatches that are already fitted.
The deck is flat it then joins with another bit with a 45 degree angle and then another 45 degree join to the base of the boat. It is the deck join that has gone. I know to repair it I will need to fit a new hatch.
      A ____Deck________
     /side deck
   |Inner deck
The join that has gone between Deck and side deck marked A. This is in the main impact zone. Just where my big and lardy goes!
I know it needs a repair on the inside so a hatch is required.
The tanks are all wood.
Any help and assistance is much appreciated.
Edited by jamesewanharvey
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 08 at 12:58pm
A photo might be good... Tanks are always a nasty fix because of the access. Its difficult to know how much good a hatch will do for you... Has the glue join failed or has the ply delaminated at the edge? How old is the boat? If you think its gone from repeated impact on the deck then the concern is stopping it doing it again... Especially if she's a pretty new boat...
You know I might try a quick and dirty on this one before going serious... Get the boat under cover and really dry out the crack. Put a thin screwdriver or too in to open it up slightly and then use a hair dryer (hot air stripper too vicious, it will take off the varnish of course) to really dry out the crack. Use a scalpel or something to get every bit of rubbish you can out. Now prop the boat up against the wall so that the crack is vertical. Mix up some epoxy with just a tad of microfibres in it and warm it so its runny (v small quantities) and dribble it down the crack. Make a dam or something with parcel tape so it doesn't go everywhere. Once the crack is all wet with epoxy bang a staple or two in to hold the ply down and let it cure. I reckon you've got a 50/50 chance of it holding for a couple of seasons, and its shed loads less work. Getting the boat positioned so the epoxy will dribble down the crack with gravity is essential...
If this doesn't work... If the deck really isn't coping with the loads you are now putting on it then, reluctantly, the best cure is to rip the decks off, clean everthing up properly and put in some extra deck beams. I like to use styrofoam (eg Dow Floormate) to support ply decks these days as it spreads the load so much better for the same weight as ply/timber beams.
You might be able to fiddle in a beam through a hatch I suppose, but it really would be a lot of hassle to get a good fit... I wouldn't fancy it. Maybe a better wood worker than I would be happy to do it.
Edited by JimC
Post Options Post Options   Quote jamesewanharvey Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 08 at 6:15pm
Hi Jim hows the canoe going?
I was going to reinforce the inside with glass and reseal the outside with liberal layers of varnish as a quick fix.
Would a stack of styrofome laid horizontally do or would it be better to have one peice vertically?
I will get some pictures tommorow
All always your assistance is much appreciated.
Lukepiewalker View Drop Down
Post Options Post Options   Quote Lukepiewalker Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 08 at 9:53pm
Could you tape put glass tape on the outside too, in a Mirror stylee?
Ex-Finn GBR533 "Pie Hard"
Post Options Post Options   Quote jamesewanharvey Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 08 at 8:45am
I could but It woud look awful even if I did a good job.
The boat is tidy for its age.
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 08 at 5:00pm
I don't think it matters much how the styrofoam is assembled provided its there and supporting the deck. Obviously its got to make good contact with the tank side and the hull shell to give the most support. I think it would be exceeding difficult to do through a hatch: I's sure I'd lose my temper and start throwing things around if I tried! Doing it in say three pieces epoxied together might be more practical.
You do want something a bit more rigid than the lighter packing grades though, the Floormate seems good. I'd definitely get epoxy in there rather than varnish no matter what, nd gravity really is your best buddy, so position the boat carefully. Worn tyres from your local (motor)bike shop are ideal in the shed I reckon.
Post Options Post Options   Quote Lukepiewalker Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 08 at 6:39pm
Actually I have a friend who had someone accuse him of not taping the rear tank in his mirror because the tape was virtually invisible.
Post Options Post Options   Quote jamesewanharvey Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 08 at 7:30pm
Sounds like I sould get him on board!
HannahJ View Drop Down
Post Options Post Options   Quote HannahJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 08 at 10:54pm
They rebate the tape on Mirrors, that's why it doesn't show.  Or some do, anyway
MIRROR 64799 "Dolphin"
