New Posts New Posts RSS Feed: Worn centreboard pivot hole
ColH View Drop Down
Post Options Post Options   Quote ColH Quote  Post ReplyReply Direct Link To This Post Topic: Worn centreboard pivot hole
    Posted: 13 Jan 08 at 4:57pm
I've lifted the centreboard out of the 'ball and noticed the pivot hole is slightly worn. It has a bit of elongation at approx the 45 degree angle (which I suppose makes sense: the crossover of max leverage on board and least support by the case); placing the end of the bolt into the hole I can swing the bolt back and forth such that the head arcs through about an inch of travel. There isn't really much slack in the hole apart from this, and the hole in the case is nice and tight.
So I'm wondering if I ought to drill and bush the hole - i.e. is it a serious amount of slop - and what would be the best material for bushing? (The board is glass-sheathed wood, btw).
olly_love View Drop Down
Post Options Post Options   Quote olly_love Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 08 at 5:13pm
drill the hole bigger then put some tape on the other side or a bit of plastic and pour some epoxy into the hole then re drill it
TWO FRANK-Hunter Impala
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 08 at 6:22pm
Not pure epoxy though. Make a mix heavy on silica gel and some microfibres too.
ColH View Drop Down
Post Options Post Options   Quote ColH Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 08 at 3:35pm
I'm also having a trawl round for glass-filled nylon or PTFE tubing, though having an imperial bolt doesn't help
