Board/case fit issue |
Post Reply | Page 12> |
tack'ho
Really should get out more Joined: 08 Feb 06 Location: United Kingdom Online Status: Offline Posts: 1100 |
Topic: Board/case fit issue Posted: 19 Nov 07 at 7:12pm |
I have just got a nice shiney Europe and the guys who shipped it over from the USA (it's ex us Olympic kit) put all the best looking bits with the boat I got. What his means however is the very pretty Mastrom Board is slightly too fat for the case! By slightly I mean I can push it down and move it but it is scratching the varnish on the Board. Should I just accept this (very pretty board!! ) try to slim the board slightly and revarnish or try to widen the slot a little? Any ideas?? |
mike ellis
Really should get out more Joined: 30 Dec 05 Location: United Kingdom Online Status: Offline Posts: 2339 |
Post Options Quote Reply Posted: 19 Nov 07 at 8:11pm |
i would geuss making the board narrower would be more risky than making the slot wider as if you narrow the board theres the risk it could end up assymetric. and noone can see the inside of the case whereas if you adjust the board and it ends up not looking sonice next time you swim everyone will see it. Edited by mike ellis |
Also International 14, 1318 |
tgruitt
Really should get out more Joined: 02 Dec 04 Online Status: Offline Posts: 2479 |
Post Options Quote Reply Posted: 19 Nov 07 at 9:47pm |
No, surely it's much easier to make the board narrower? Is it the actual blade that is too fat, or just the bit that always stays inside the case?
timnoyce
Really should get out more Joined: 05 Aug 04 Location: Hampshire Online Status: Offline Posts: 1991 |
Post Options Quote Reply Posted: 19 Nov 07 at 10:29pm |
I think that you'll find that making the case wider will be a pain in the arse! In all our boats the case is laminated on a mould, and then built in when the boat is joined... apart from sand off all the gel on the inside to make it wider I can't think of another way to remedy it unless you want to cut you boat up and fit a new one?!
Merlinboy
Really should get out more Joined: 03 Jul 06 Location: United Kingdom Online Status: Offline Posts: 3169 |
Post Options Quote Reply Posted: 20 Nov 07 at 8:30am |
shave the board down! If your major worried about the boad send it away to someone like Millanes and get them to refinish it for you !
Franco
Groupie Joined: 15 Jan 07 Location: United Kingdom Online Status: Offline Posts: 40 |
Post Options Quote Reply Posted: 20 Nov 07 at 1:17pm |
If it goes in and you can use it, leave it alone. You just need to clean your slot or use a lubricant. The scratching will probably be dirt in the case. P.S. It's not varnish. |
mike ellis
Post Options Quote Reply Posted: 20 Nov 07 at 6:11pm |
oeydokey, ignore me, i was only geussing. |
tmoore
Really should get out more Joined: 01 Nov 07 Location: Wales Online Status: Offline Posts: 880 |
Post Options Quote Reply Posted: 20 Nov 07 at 7:23pm |
im fairly sure this happens with most new boards. For certain it does in all rudder stocks i have ever came across. (apart from the cool vertically loaded ones) tom |
Landlocked in Africa
Graham T
Posting king Joined: 09 Apr 07 Location: United Kingdom Online Status: Offline Posts: 123 |
Post Options Quote Reply Posted: 20 Nov 07 at 8:07pm |
See various posts on the duffers topic re lubricating boards then sliding off them after capsition...........
Osprey 55 "Tebutinnang"
Osprey 1245 "Two Bob Bit" Miracle 1358 "Thumper" |
Lukepiewalker
Really should get out more Joined: 24 May 06 Location: United Kingdom Online Status: Offline Posts: 1340 |
Post Options Quote Reply Posted: 20 Nov 07 at 9:06pm |
Maybe it's a necessary evil, so the board can be anglesd in the case. Or am I just imagining seeing Europes doing that...
Ex-Finn GBR533 "Pie Hard"
