long lycra trousers |
Spot192
Really should get out more Joined: 28 Nov 04 Location: Germany Online Status: Offline Posts: 833 |
Topic: long lycra trousers Posted: 28 Nov 04 at 12:13pm |
in germany threre arenīt many chances of buying good sailing clothes.
so iīm asking here in this forum if anyone knows a label which produces
long lycra trousers, because iīm allergic to neoprean and in skiff
sailing you canīt sail in a nice skirt! i hope you can help me!
sailor girl
Really should get out more Joined: 13 Jun 04 Location: Spain Online Status: Offline Posts: 1031 |
Post Options Quote Reply Posted: 28 Nov 04 at 4:04pm |
try rooster sailing gear, they might have
www.roosersailing.com - i think!!!! |
iansmithofotley
Far too distracted from work Joined: 16 Mar 04 Location: Otley, West Yorkshire Online Status: Offline Posts: 209 |
Post Options Quote Reply Posted: 28 Nov 04 at 4:09pm |
Hi Fiona, Why not consider wearing a Dry Suit with a 'woolly bear' or thermals or both, depending on the weather. In very hot weather it would probably be inappropriate, but then you might not be wishing to wear a neoprene suit anyway and would get away with spray top and shorts or tight tracksuit bottoms. If you did wish to buy 'long lycra trousers' then a racing cyclists' shop would be able to help, you can even get them with 'bib and braces' so they would not work their way down. Ian (Yorkshire Dales S.C.) Edited by iansmithofotley |
Spot192
Post Options Quote Reply Posted: 01 Dec 04 at 1:41pm |
thanks for your help! i went to cycling shop and now iīm the
proud owner of some leggins. i already tried to sail in a dry
suit, but the big problem with it is, while a tack in the int 14 you
get cought on every little item.you really helped me both!
servus Fiona |
