laser underside gunwale |
alex d
Newbie Joined: 16 May 05 Location: United Kingdom Online Status: Offline Posts: 17 |
Topic: laser underside gunwale Posted: 23 May 07 at 4:20pm |
Can any one advise me on gunwale repair. On the underside of my gunwale there are small area's where it looks like the different coats are separating. This is looking from underneath where all the coats come to an end/edge of gunwale. Should I just turn the boat upside down and use some gelcoat filler (which I( already have) or something else. Or is it not that important?
les5269
Really should get out more Joined: 11 Oct 05 Location: United Kingdom Online Status: Offline Posts: 1530 |
Post Options Quote Reply Posted: 23 May 07 at 7:59pm |
you could always try opening them out a bit and put epoxy in, then clamp them closed until it's set. I have no idea if this would work but I would try it if it was me. |
alex d
Post Options Quote Reply Posted: 23 May 07 at 10:55pm |
i forgot to say this is a laser Edited by alex d |
Paramedic
Really should get out more Joined: 27 Jan 06 Location: United Kingdom Online Status: Offline Posts: 929 |
Post Options Quote Reply Posted: 24 May 07 at 7:25am |
Turn it over and run some polyester resin in. Don't use epoxy, it doesn't stick well to polyester and the problem will only return later and worse!
jeffers
Post Options Quote Reply Posted: 24 May 07 at 8:52am |
Alex,
Is this where the hull and deck mouldings join or actually in the recess where the gunwhale hung trolley sits? Either way I would recommend something a bit more than just gelcoat filler. Regards, Paul |
alex d
Post Options Quote Reply Posted: 24 May 07 at 1:58pm |
It is where the hull and deck mouldings join. It's just small areas but I figure i might as well deal with them while they are small.
alex d
Post Options Quote Reply Posted: 24 May 07 at 2:21pm |
Can I just use the polyester resin from halfords This is there quicksand ployester filler that says can be used on various surfaces inc gpr etc. The problem with buying online is the hardener has to be courier only so the cost becomes about £30 as opposed to halfords £8 |
Paramedic
Post Options Quote Reply Posted: 24 May 07 at 5:28pm |
Halfords resin is fine but you can get it cheaper. Any supplier of fibreglass will be able to help.
Paramedic
Post Options Quote Reply Posted: 24 May 07 at 5:29pm |
Please note you do NOT want filler, you want resin. You need to glue the mouldings back together and filler has no real adhesive properties.
