New Posts New Posts RSS Feed: RS200
RS200
Mark Aged 42 View Drop Down
Post Options Post Options   Quote Mark Aged 42 Quote  Post ReplyReply Direct Link To This Post Topic: RS200
    Posted: 11 Oct 21 at 7:59am
My club has no adult 2 man class, but I have a hankering for a 2 adult boat for me and Mrs MA42 to race in the occaisional club handicap event.  Lasers will remain the weapons of choice.
So, theres an RS200 for sale near me, and that class does have a fine reputation. Does the RS200 have any well known problems with the hull or rig? What to look for when inspecting it?
Mozzy View Drop Down
Post Options Post Options   Quote Mozzy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 21 at 8:22am
Old deck, look for longitudinal crack on the underneath of the hull running where the toe straps are. Also check the deck for flex where the toe straps attach, either or both of these is a sign of the skin coming away from the stringers and is quite an expensive repair. Or, you might find some obvious changes in gel colour on the underside from the front of the case going back where the repair has previously been done, which is probably a good sign for an old boat as I've not heard of them going twice!
Check the boom for cracks at the kicker fitting. High loads an a bit of corrosion between steel and alloy here make it a common failure point. The old poles can wear through at the bow where they are strapped down with the steel band.
On the new deck boats (1600+) check the rudder gudgeons have been bolted on not screwed. Also check where it hangs on the trolley arms as the hull can crack at the gunwall and flair out (the older hulls had rib of reinforcement here, which also stopped the boats slipping off the trolley, shame that feature was lost).
Generally, they are a pretty robust boat and even a very old hull, with some new fittings and ropes, and attention to settings will be competitive. Luke just won the endeavour with a 21 year old boat.
Edited by Mozzy - 11 Oct 21 at 8:24am
Post Options Post Options   Quote Mark Aged 42 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 21 at 7:52am
Mozzy, thanks for this info. Keep up the good work on your YT channel, its very educational and interesting.
Sussex Lad View Drop Down
Post Options Post Options   Quote Sussex Lad Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 21 at 8:30am
Had one of the old ones briefly a few years ago but decided to go back to symmetric.
So apart from it being an assy which didn't suit us the three things that I found to be irritations:
It does have an open transom but don't let that fool you. If you get water in it it will take quite a while to get rid of. Inefficient bailer with a bowl shaped cockpit. So capsizes, hove to between races and launching (water comes in through the internal bung if you forget to put it in), and big seas.
Spinnaker chute was an afterthought during design so it's a bit tight and does take a lot of wear because it sticks up. Ours was coming apart at the seams and was near impossible to repair. Wear and tear on spinny resulting. Also extra wear and tear on the foot of the jib.
The RS 200 was advertised as a lightweight boat at the time with some ridiculous weight quoted on their website. Turns out the weight quoted was for an unfitted hull and the actual hull weight was not particularly light. RS have since amended their advertising.
No doubt good technique and  work arounds help for some of these issues
Edited by Sussex Lad - 12 Oct 21 at 9:06am
eric_c View Drop Down
Post Options Post Options   Quote eric_c Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 21 at 10:46am
For an asy boat, they are terribly slow.
Even slower than their PY suggests.
Their PY and reputatiuon is boosted by many very good younger sailors sailing them in strong breeze.
The 400 is a far better boat unless you are on the small side and want to sail in near gales.
There was an article in the RS class mag some years back showing the build process for a 200. The words 'brush and bucket' are apt. A lot of these boats are overweight, leak,have gone soft etc. They used to be inexpensive and many of them have had hard lives doing a lot of road miles on the circuit.
The sails have been upgraded in recent years.
RS Rudder blades of a certain vintage had a rep for cracking, even breaking below the stock.
L192444 View Drop Down
Post Options Post Options   Quote L192444 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 21 at 3:52pm
Given they are very heavy why did they go gunwhale hung trolley? They all seem to deform on the load point.
Post Options Post Options   Quote L192444 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 21 at 4:10pm
Good point the website still quotes 78kg for the hull weight but that must be before the fit it out and add the pole, thwart etc ... not what most of us would consider the definition of hull weight.
Says on their website that the sailing weight is 114kg so that is another 36kg of stuff on top of the hull ...
For an occasional 2 hander I'd go with a National 12 or Tasar, both far more pleasing to sail and a lot easier to pull up the beach afterwards.
Edited by L192444 - 12 Oct 21 at 4:12pm
ClubRacer View Drop Down
Online Status: Online
Post Options Post Options   Quote ClubRacer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 21 at 5:35pm
The 200 PY isn't actually that good in breeze, short hull, draggy main, small spinnaker and fairly heavy hull make it hard work upwind and slow down. Ever thought the youths that sail the boat well in wind are...you know...pretty good?
Its only sweet spot is the medium range between 5-10 knots when you're in full power mode.
The gunwale hung trolleys are only an issue on the newer ones. The benefit of the gunwale hung when done right is it removes the dents you get on the bottom of the hull when sat on a cradle for years.
Post Options Post Options   Quote eric_c Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 21 at 5:57pm
As I said the PY is quite slow and the boat is generally slower still.
A lot depends on what you will be race against, at some clubs you'll be in the 'medium' fleet mostly racing against singlehanders.
What courses you get will make a difference too, if you get a lot of reaches at just the right angle and no proper leeward legs, any asy suddenly looks good. If you get a lot of  runs, boats of similar PY and a proper kite will go direct and be all over you.
Some boats don't really play nicely in a mixed handicap race, IMHO the best reason to be buying one is to race against others of the same design.
Of course if you really don't care about the results, you may find any boat with a kite is more fun than one without. But then there are many other classes in the genre for less cash, if that matters?
Making a boat that size and weight with the gunwhales not up to a gunwhale-hung trolley sounds like an epic fail.
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 21 at 6:19pm
What a remarkably negative thread. The 200 is a sweet little thing, if rather too small for my over substantial frame at the front end.
Its the most popular two handed class in the country for good reason. Its in the nature of the beast for a low powered boat that must be little over 12 foot waterline not to be warp speed fast, but its the quickest two hander in its size range on the PY list, and quicker than a N12, even a Lark and quite a few other longer boats. Indeed there are precious few sit on the side pole kite boats of any length that are much faster. As for the PY, due to the large numbers racing its one of the best attested numbers out there.
