New Posts New Posts RSS Feed: convert from a small yacht to a dinghy
pij27 View Drop Down
Post Options Post Options   Quote pij27 Quote  Post ReplyReply Direct Link To This Post Topic: convert from a small yacht to a dinghy
    Posted: 25 Jan 21 at 3:41pm
I have sailed a small yacht and crewed other yachts for a few years and always looked at a dinghy with some trepidation due to them appearing to capsize with ease, However, recently have been reading a lot on dinghy cruising and general sailing and think it is time to start. Any advice as to whether should start with something like a laser or a wayfarer? Do a course? Or join a club and sail there?
Should I hold off on buying a dinghy or jump in and learn on my purchase?
All thoughts and advice greatly received
rich96 View Drop Down
Post Options Post Options   Quote rich96 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 21 at 4:05pm
Hi
Definitely do a dinghy sailing course and then decide what you want
Lots of great 'cruising' dinghies that are less likely to tip you in
Really depends where you sail and what you want to achieve
tink View Drop Down
Post Options Post Options   Quote tink Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 21 at 8:07pm
Welcome to the light, dinghy sailing is proper sailing. It is best to join a club if you would like to get into racing, not as scary as it sounds. If you’re more interested in pure cruising then work contacting the Dinghy Cruising Association- they have an active Facebook group it that’s your bag. The boat depends on many factors, cruising or racing? budget, your weight and fitness.
Tink
https://tinkboats.com
http://proasail.blogspot.com
Sam.Spoons View Drop Down
Post Options Post Options   Quote Sam.Spoons Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 21 at 11:52pm
Dinghies capsize with varying degrees of ease but they can usually be recovered likewise. Generally speaking the less stable dinghies like Lasers and modern open transom/double bottom boats are easy to recover and come up dry enough to continue sailing immediately. More traditional dinghies like the Wayfarer are much harder to capsize but recovery is usually more protracted as they will have a fair bit of water in the cockpit which will need bailing out.
Some old designs have been updated with double bottoms (Ent and GP) and others like the OK have always had a small cockpit which doesn't hold too much water after a swim.
If cruising is your thing look for something designed for the job and learn not to capsize (not too difficult TBH). If racing or going fast is what lights your candle then you won't go far wrong with an old Laser as a first dinghy and learn how to recover from a capsize, you'll soon stop worrying about it.
Edited by Sam.Spoons - 25 Jan 21 at 11:53pm
Post Options Post Options   Quote pij27 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 21 at 1:00pm
Thanks for the advice, will look at the local clubs and do a course through one of them
