New Posts New Posts RSS Feed: Sail stains
Sail stains
Wetabix View Drop Down
Post Options Post Options   Quote Wetabix Quote  Post ReplyReply Direct Link To This Post Topic: Sail stains
    Posted: 18 Nov 20 at 12:24pm
Does anyone know how to get rid of the small rust coloured stains that sometimes appear on sails, sailbags and the like during storage?
423zero View Drop Down
Post Options Post Options   Quote 423zero Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 20 at 2:04pm
Oxalic acid.
Robert
Post Options Post Options   Quote Wetabix Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 20 at 9:21pm
er... just remind me where I can find oxalic acid. (Oh - and thanks for the tip)
Post Options Post Options   Quote 423zero Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 20 at 9:47pm
Ebay, amazon, I got mine from Wilko, years ago though.
Robert
Post Options Post Options   Quote Wetabix Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 20 at 11:11pm
I believe there's quite a lot of it in rhubarb stems!
Post Options Post Options   Quote 423zero Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 20 at 11:26pm
Yes, plants contain a lot, red colour might cause an issue thoe lemon supposed to be good.
Robert
ColPrice2002 View Drop Down
Post Options Post Options   Quote ColPrice2002 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 20 at 9:51am
Hi,
If these are rust stains (eg from the luff wire), then either oxalic acid or citric acid will complex with the iron and you can then wash it out with plenty of fresh water.
I'd prefer citric acid - oxalic acid is toxic (which is why you don't eat rhubarb leaves!).
If it's a mold type stain, then use diluted bleach and a little scrub. In all cases rinse well.
There are more effective chemical treatments, but the sailcloth may not like the !
Post Options Post Options   Quote Wetabix Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 20 at 10:16am
Thanks for that - the stain is tiny but it is right in my field of view (close to the mast by the third batten. I believe it to be fungal in origin caused by putting the sail away while damp. It is my storm sail and I haven't used it since the beginning of the season. I was going to try bleach but my wife says it will dissolve the sail. A tiny drop perhaps.
Rgds
George Morris
Weta 117
Sam.Spoons View Drop Down
Post Options Post Options   Quote Sam.Spoons Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 20 at 12:19pm
This article refers to mildew but does refer to using household bleach on sails so might be useful.
Post Options Post Options   Quote Wetabix Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 20 at 12:30pm
OK, it looks like I won't be using bleach! Thanks for that.
