Adjustable raking systems |
Page 123> |
iGRF ![]() Really should get out more ![]() ![]() Joined: 07 Mar 11 Location: Hythe Online Status: Offline Posts: 6028 |
![]() ![]() ![]() ![]() Posted: 17 Nov 20 at 9:56am |
One for the technically minded this.
I'd like a single string raking system that adjusts the lowers simultaneously. I'm sure I've seen it in Merlin World and wonder if anyone has some sketches as to how the pulleys line up. My second question is, insteaad of raking the mast back top down has anyone ever come across anyone sliding the bottom of the mast back and forth windsrf longboard racing style, pivoting around the top spreader shrouds? (Obviously the lowers would have to adjust in concert also) Edited by iGRF - 17 Nov 20 at 9:57am |
davidyacht ![]() Really should get out more ![]() Joined: 29 Mar 05 Online Status: Offline Posts: 1085 |
You probably should delve in the various Merlin Rocket forums, since I believe that there are two types of Merlin one string systems. Look on the main website and also the Merlin Revival Facebook pages.
Unless you are a consummate boat bimbler you might look to get one of the Merlin gurus sort it for you.
Dick Batt had a ramp system for the mast foot, I think on Danger Bat. This might be less complex. I suspect that you could achieve 90% of this by having a decent forestay tensioning system and a decent and powerful shroud tensioning system, and ensuring that these are carefully calibrated. In National 12s we simply dumped the shroud tension at the windward mark to allow the main to square off, and pulled it back on at the leeward mark. We had three windward rake settings marked off on he control line ... light, medium and windy. |
Happily living in the past
Gordon 1430 ![]() Far too distracted from work ![]() Joined: 27 Jun 17 Location: Lee on Solent Online Status: Offline Posts: 254 |
HI Grf
I had a 505 which had tracks on the shrouds so you could adjust them fore and aft in conjunction with raking the rig. You have a short length of tack on each gunnel with a car on top which the shrouds attach to and the cars have a control line to pull forward or aft. Mr Henshall might have some images of Grace which may have been one of the first with this system. Good Luck Gordon |
Phantom 1430 |
Grace ... special boat
Rupert ![]() Really should get out more ![]() Joined: 11 Aug 04 Location: Whitefriars sc Online Status: Offline Posts: 8761 |
A moving mast foot pivoting round the hounds will rake the mast but affect CofE rather differently. Good or bad I don't know.
H2 ![]() Really should get out more ![]() ![]() Joined: 26 Jul 17 Online Status: Offline Posts: 610 |
I think Tasar use a track at the shrouds too?
H2 #115
Dougaldog ![]() Far too distracted from work ![]() Joined: 05 Nov 10 Location: hamble Online Status: Offline Posts: 326 |
Mr Henshall has indeed pictures of the tracks and of the hydraulic shroud tensioners that were fitted at the time. In the end, Chris Haworth did this best...Merlins and 5o5s! However, with the ready availability of modern, low friction/high load blocks, the complication that the system introduced could be best handled with a merlin style one string. What is really needed here is the Jon Turner 'big wheel of love' but my gut feel is that the cost of doing this will drive the man of Kent into another rage - even a fairly bog-standard one-string system on a Merlin can gobble up a cool £1000+ in hardware and cordage. Sadly, the OP won't accept that this has been done before, albeit somewhat differently - who can forget that Jon Turner (one of our great innovators of things that work) had a system on Dark Star that allowed the rig to be heavily canted to windward.
The $64,000 question though.... all that knowledge and expertise in one boat (Turner and Richard Parslow) and a fully functional system - get they didn't proceed to develop it further - which must beg the question...why not! Dougal
Dougal H
A2Z ![]() Really should get out more ![]() Joined: 10 Oct 16 Online Status: Offline Posts: 501 |
Does your Fireblade need lowers, spreaders or even shrouds? Stick an OK or D Zero rig on it and have a sliding mast foot. Much easier, tidier and cheaper than a Merlin one string system.
Well, let's see them then? Why didn't they continue? Easy obvious answer to that. ![]() I came across this Supernova, it was allegedly the 2014 Nationals winner on display at some show or other, but it had some sort of system, wish I'd paid more attention and taken more pics. ![]() |
Well I assumed because I want to trapeze from it, it would need additional support, has anyone ever trap'd off an unstayed rig? Is it do-able? I agree getting rid of all that dross would be great but.... |
Page 123> |
