New Posts New Posts RSS Feed: Thinking of buying a Wanderer
wanderer101 View Drop Down
Post Options Post Options   Quote wanderer101 Quote  Post ReplyReply Direct Link To This Post Topic: Thinking of buying a Wanderer
    Posted: 25 Oct 20 at 7:36am
Hi All,
I am thinking of buying a Wanderer and have found a possible candidate. It needs some work in general to tidy it up but the one thing that worries me slightly is that I see evidence of rust inside the boat coming through the GRP from the lower right hand shroud screw.
Would I be right to worry or is there nothing to be concerned at here?
Richard
Old bloke View Drop Down
Post Options Post Options   Quote Old bloke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 20 at 8:24am
Short answer is dont worry about it.
Stainless steel is really less staining steel and its common to get a little rust staining.
Its a 10 minute job to remove the fitting, then clean and/or replace as required
NicolaJayne View Drop Down
Post Options Post Options   Quote NicolaJayne Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 20 at 11:02am
and a common  problem with  stainless fittings  and rust is poor attention ot detail  with regard to the same grades of stainless being used  - mixing a2 and A4  (304 and 316)  can lead to some interesting   outcomes
Sam.Spoons View Drop Down
Post Options Post Options   Quote Sam.Spoons Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 20 at 9:58am
IME A2 is not good in seawater* but is fine in fresh, if somebody has bought 'stainless steel' fixings from B&Q, Screwfix or Toolstation to replace something on the boat they will probably be A2 (Toolstation stainless fixings are definitely A2 and are very cheap but it's a limited range of sizes).
* Actually A2 is usable in seawater if you rinse in fresh water after sailing but will rust if you don't, A4 is much better.
whitsundays View Drop Down
Post Options Post Options   Quote whitsundays Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 20 at 12:49pm
Look what I found for you. https://www.getmyboat.com.au/journal/how-to/tips-to-avoid-stainless-steel-corrosion-on-boats/.
Take a few minutes to read this. I am sure this article will help you out.
Whitsundays Yacht Charters
