Approaching a mark on port meeting running boats |
davidyacht ![]() Really should get out more ![]() Joined: 29 Mar 05 Online Status: Offline Posts: 1086 |
![]() ![]() ![]() ![]() Posted: 12 Aug 20 at 9:39pm |
I shall risk pillory ... but I am interested in a better understanding.
Approaching a port handed windward mark on port tack (slightly over standing due to a wind shift) I was confronted my boats having rounded the mark on starboard or port gybe. My solution was to sail high to avoid them then run down when there was a gap to round the mark. But as I read the rules they had previously completed their entitlement for mark room and so this becomes a port starboard windward leeward boat situation ... in which case I could have held my course to the mark and did not need to anticipate that they were going to bear off in front of me after they had rounded the mark. Or would I have right of way over the port gybe boats but not the starboard? In defence of the venue, we have rounded this Mark for many years without the need for a spacer mark!
Happily living in the past
Brass ![]() Really should get out more ![]() Joined: 24 Mar 08 Location: Australia Online Status: Offline Posts: 1044 |
Rule 18 does not apply between a boat approaching a mark and one leaving it (rule 18.1(c)).
You are required to keep clear of starboard tackers (rule 10), and boats that gybe-set onto port under your nose will be windward of you, same tack and required to keep clear of you (rule 11). |
Thanks Brass (as ever), what was confusing me was “A give-way boat is not required to anticipate a right-of- way boat's alteration of course“ referred to in the case books, which made me think that a right of way boat cannot change course into the path of another boat even if that boat does not have rights ... but of course this happens all the time, so I was probably over thinking it.
My instinct at the time was as you interpreted ... I had rights over the boats that had gybed onto port but not on those that had borne off on starboard.
So the case you are thinking about is
Rule Rule: 16.1" data-url="/rules/875?xformat=fleet" style="box-sizing: border-box; background-color: transparent; color: rgb(51, 122, 183);">16.1, Changing Course Rule Rule: 36" data-url="/rules/664?xformat=fleet" style="box-sizing: border-box; background-color: transparent; color: rgb(51, 122, 183);">36, Races Restarted or Resailed Rule Rule: 60.1" data-url="/rules/518?xformat=fleet" style="box-sizing: border-box; background-color: transparent; color: rgb(51, 122, 183);">60.1, Right to Protest; Right to Request Redress or Rule 69 Action A give-way boat is not required to anticipate a right-of-way boat’s alteration of course. As always you can't just rely on the headnote, you need to read the case. In this case the circumstances described make it clear that this is a dead set rule 16.1 "P had no opportunity to take evasive action, since S swung directly into the collision." You're certainly not required to do anything before you are close, on converging courses, but woe betide you if you don't act promptly once you are. Edited by Brass - 13 Aug 20 at 8:17am |
