Plywood Kit Designers |
Page 123 7> |
Sid92 ![]() Newbie ![]() Joined: 24 Jul 20 Online Status: Offline Posts: 7 |
![]() ![]() ![]() ![]() Posted: 24 Jul 20 at 6:06pm |
After many years of double handed dinghy sailing I'm looking to get a single hander due to the Covid situation.
After reviewing whats available in the market I'm struggling to find a suitable craft so am looking at the potential for a modern ply constucted design which could be made by a competent diy er. My thinking is something about 14ft capable of carrying weight with a deep ish cockpit to ensure no kneeling is required. A hiking single sail boat using a Phantom carbon mast (or similar) and a similar sail design / area to reduce development costs. The ideal design would be one with enough rocker to support inland sailing on restricted waters but still be a fast boat. Appreciate there are many designs available currently but in my mind they are all for sub 105kg sailers with the young and agile in mind. I have previously sailed Phantoms,Ok's, contenders but some time ago. The design / construction would be along the lines Leech OK project. Can anyone think of any suitable UK designers? |
Rupert ![]() Really should get out more ![]() Joined: 11 Aug 04 Location: Whitefriars sc Online Status: Offline Posts: 8764 |
Keith Callaghan designed the Hadron - take a look. It morphed into the H2
Nessa owned one will know more. |
JimC ![]() Really should get out more ![]() ![]() Joined: 17 May 04 Location: United Kingdom Online Status: Offline Posts: 6358 |
There are arguably two separate design challenges. The first is to get a shape, which arguably could be one of the existing classes, and the second is to generate a millimetre accurate cad/cam file to cut the ply from. The second is arguably the bigger challenge.
Thanks Rupert I have tried an H2. Its a nice boat but for lighter helms.
I would think 12 - 13 stone is ideal for the H2 I'm looking at something comfortable for 14.5 stone helms plus..I'm at 17 stone and relatively fit but at over 6ft it needs to be more on the scale of a Megabyte which is a nice boat from a hull design point of view but again would suggest the rig is designed for lighter weights. (Also its imposible to find then for sale..) |
Thanks Jim, what class were you thinking? I did think something along the lines of a scaled up streaker might be similar to what I imagined although with a bit more beam or so ething like the Sabre or Impulse from Australia?
The original Hadron appears to have a bit more volume to it, but it may be that the designer can tweak it, or already has a design up his sleeve. Otherwise, most home build ply designers are concentrating on cruising boats. I know some big people who have owned Megabytes, certainly more than 17 stone, if they will forgive me saying. Like hens teeth though in the UK. |
Daniel Holman ![]() Really should get out more ![]() Joined: 17 Nov 08 Online Status: Offline Posts: 986 |
You can build a phantom from sheet ply, I know that there are glass boats with "wells" to give less than appalling downwind ergonomics, so that arrangement could be replicated in ply. Is there any reason why you wouldn't want a phant? If for whatever reason thats not cool and you don't want something completely custom, have a look at the woods designs stealth or zest: http://boatplans.cc/woods-designs/stealth/ https://www.sailingcatamarans.com/index.php/designs-2/46-beach-cats-and-dinghies/436-zest Richard Woods is the daddy at ply kit designs albeit generally on larger multihulls |
I enjoyed the Phantom I had but found current design to be very hard on the knees.. I like the look of the JJ deep cockpit versions but still feel there are poor ergonomics for the deep offwind work and you also have the low boom issue.
KazRob ![]() Far too distracted from work ![]() ![]() Joined: 22 Oct 16 Location: Scotland Online Status: Offline Posts: 210 |
Why not speak to Dan Leech to get a design done? Maybe he could stretch the OK out a bit more into something for you (although his new Mk4 OK is aimed at ~105kg helms). He charges 600NZ$ for the OK cad files (~£300?) to get the boat and jig panels cut so it may save you time an money in the long run.
For those that like something more radical than the OK, he does some other cool boats too http://www.leechboats.com/sail BTW - well worth getting a try in the OK class demo boat. Lots of sailors (inc me) over 6ft and 100+kg in them. Think the rig might be further forward and more upright than you maybe tried before.
Edited by KazRob - 24 Jul 20 at 7:45pm |
OK 2139 & 2148
CapSizer ![]() Newbie ![]() ![]() Joined: 29 Dec 05 Online Status: Offline Posts: 18 |
Why is a single-floor ply Phantom out of the question?
Page 123 7> |
