Windvane self-steering |
OlKeat ![]() Newbie ![]() Joined: 03 Dec 19 Location: Europe Online Status: Offline Posts: 4 |
![]() ![]() ![]() ![]() Posted: 25 Dec 19 at 1:41pm |
Hello
everyone, happy holiday! What can you say about the windvane self-steering,
based on the experience of use, which is better: auxiliary rudder or
servo-pendulum? |
snowleopard ![]() Groupie ![]() ![]() Joined: 02 Oct 17 Location: Cornwall Online Status: Offline Posts: 64 |
The biggest factor is the configuration of the boat. For example a Folkboat can be steered with a trim-tab on the rudder but most modern boats don't have a transom-hung rudder. Pendulum-servo gears work best with tiller steering. I had one on a wheel-steered boat and the length of the linkage made it a bit sloppy.
My latest boat was equipped with an electronic autopilot which operated via a hydraulic pump. I sailed 20,000 miles with that arrangement and it never let me down, plus I could select a waypoint on the GPS, press 'Track' and know I would follow a line on the chart to within 50 metres. Personally I'd never go back to wind-and-string solutions.
I studied in more detail the features of their work, and I came to the same conclusion, it is better to put an electronic one and not have unnecessary trouble :) Thank you, your review finally convinced me of this.
Having said that. If an electronic autopilot fails, you have a serious problem. We met a couple in Bermuda who had had steered from Antigua when theirs failed. After various failed attempts to get it fixed, they recruited a couple of extra crew to get them back to Europe.
Instructive story. It should take into account their experience
Sam.Spoons ![]() Really should get out more ![]() Joined: 07 Mar 12 Location: Manchester UK Online Status: Offline Posts: 2960 |
How repairable is a wind vane steering rig by an average cruising sailor on the open sea miles from civilisation? Not very I'd hazard*. If we follow that logic we'd only cruise in 'Spray' replicas
![]() * Admittedly more repairable than an electronic system but......
Edited by Sam.Spoons - 06 May 20 at 9:37am |
ifoxwell ![]() Really should get out more ![]() ![]() Joined: 05 Jan 06 Location: Hoo Online Status: Offline Posts: 663 |
I think there is a place for both. An electronic solution has a lot of obvious benefits and for the kind of sailing I do is the only one that makes sense, however if I was sailing any distance then having a system that didn't consume any power would be very appealing
RS300
PeterG ![]() Really should get out more ![]() Joined: 12 Jan 08 Location: United Kingdom Online Status: Offline Posts: 774 |
Not a cheap option, but belts and braces have some appeal for long distance sailing!
Peter
