Turning Inflatable tyres into foam filled |
bdu98252
Newbie Joined: 07 Jun 05 Location: United Kingdom Online Status: Offline Posts: 30 |
Topic: Turning Inflatable tyres into foam filled Posted: 12 Dec 19 at 2:25pm |
I have a couple of optimists where the inner tube has perished and the tyres no longer hold air. I was looking to buy some of the non inflatable wheels that are quite popular but they are not cheap. Has anyone else just used some expanding foam or tyre foam to fill the tyre and then essentially have a solid wheel. Given the light weight of optimists I thought it might be worth a go as they will only get thrown otherwise.
Sam.Spoons
Post Options Quote Reply Posted: 12 Dec 19 at 2:49pm |
Builders expanding foam will soak water and disintegrate pretty quickly, tyre foam does not fill there tyre but seals a small puncture and the propellent in the can then inflates the tyre. Cheapest way is to just replace the tubes.
bdu98252
Post Options Quote Reply Posted: 12 Dec 19 at 3:39pm |
Thought that might be the case so have bought some tubes.
Sam.Spoons
Post Options Quote Reply Posted: 12 Dec 19 at 3:58pm |
