New Posts New Posts RSS Feed: Repainting an old GRP boat
EmmyC View Drop Down
Post Options Post Options   Quote EmmyC Quote  Post ReplyReply Direct Link To This Post Topic: Repainting an old GRP boat
    Posted: 29 Nov 19 at 3:04pm
I have a nice old GRP Solo that Id like to (cosmetically) spruce up before I sail it a bit next year and decide whether I want to stick with the class. Any recommendations r.e paint for the floor in particular? Brands/types/tips would be much appreciated!
Online Status: Online
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 19 at 3:24pm
Painting GRP boats overall is a bit problematic, in that the most effective paints are viciously expensive and unpleasant to handle. However if you only want to do the floor I've found International Interdeck to be surprisingly durable and straightforward to handle.
Sussex Lad View Drop Down
Post Options Post Options   Quote Sussex Lad Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 19 at 6:45pm
for the outside the international 2 packs are very durable if you use the primer but add a bit of weight.
I've used interdeck with good results. The grey looks very smart. It's very non slip i.e. quite abrasive.
piglet View Drop Down
Post Options Post Options   Quote piglet Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 19 at 9:58pm
Nooooo, don't paint a GRP boat. Once it's painted it will always have to be repainted.
And unless it's sprayed it looks kak.
imo
ColPrice2002 View Drop Down
Post Options Post Options   Quote ColPrice2002 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 19 at 6:01pm
Sorry to be late...
I painted my old grp Solo :-
Using a conventional paint (International), brush painted using about 4% flow modifier (IIRC Thinner 333 - I suspect that isn't available now!)
Reasonably good finish, but you will need to sand the gelcoat all over, then degrease to get good adhesion. It may also be worth using a grp primer.
Colin
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 19 at 8:21am
I've painted many, using most of the ideas from above, but in the end came to the conclusion that it took away one of the few advantages of GRP over wood - maintaining the thing. Scratched paint on GRP looks far worse than a battle wound.
Do Different View Drop Down
Post Options Post Options   Quote Do Different Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 19 at 11:29am
I've known people liven up faded gel coat with cutting and polishing compounds.
There is no way back after painting anything, houses, boats, all a very last and reluctant resort to my mind.
