New Posts New Posts RSS Feed: Rs300 A rig?
Rs300 A rig?
Mike7722 View Drop Down
Post Options Post Options   Quote Mike7722 Quote  Post ReplyReply Direct Link To This Post Topic: Rs300 A rig?
    Posted: 11 Oct 19 at 3:11pm
How much of a difference does the A rig on the RS300 make compared to the B? I understand it is a bit smaller, and was wondering the effect on speed, from a racing point of view?
Neptune View Drop Down
Post Options Post Options   Quote Neptune Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 19 at 3:41pm
Unless you are light (less than low 70ís kg) then go for a B rig.  Itís much easier to get new sails etc.
When it comes to sailing the A rig isnít much smaller just much flatter; you can do same thing with the controls on the B rig and the. Reap the rewards downwind and in lighter breezes.  While itís certainly an advantage above 12 knots to be heavier, above 20 itís more about technique again. Very few people race on the circuit with an A rig because imo isnít quite as fast as the B.
RS300 and RS200, ex Musto Skiff
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 19 at 3:42pm
The theory was supposed to be that lighter sailors would be as quick with the A rig as heavier ones with the B rig. It didn't work out, because it tends to be the case in a single sail boat that if you can hang on to a bigger rig upwind in any shape at all you will be way faster downhill, so in the end you needed to be a very good A rig sailor to compete at the front with the B rigs. I never did the sums, but somewhere between 5% and 10% wouldn't surprise me as that tends to be the range between front of fleet and pack.
Edited by JimC - 11 Oct 19 at 3:43pm
Post Options Post Options   Quote Mike7722 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 19 at 7:48pm
So it is a bit slower then.
Maybe at club level a sub 70kg person could race off a slightly higher py with the a rig? I'm just wondering. Obviously technique is key in any boat, especially something like the 300.
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 19 at 7:58pm
A club can do anything it likes with its handicaps, but it doesn't seem to me that would be unreasonable.
H2 View Drop Down
Post Options Post Options   Quote H2 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 19 at 9:28am
In my limited experience of sailing against 300s, the key thing is keeping it upright rather than which sail you pick. If you can find a way not to be swimming then which ever sail you pick you will go quite quick!
H2 #115
