New Posts New Posts RSS Feed: drysuit fabric 'socks'
Jumps View Drop Down
Post Options Post Options   Quote Jumps Quote  Post ReplyReply Direct Link To This Post Topic: drysuit fabric 'socks'
    Posted: 28 Jun 19 at 8:12pm
Hi All,
New to sailing and loving it,
On a RYA 1+2 couse on a cold reservoir in yorkshire and got myself a drysuit after the instuctors threatened capsize practise!
(I'm a poor swimmer and was woried that the shock of cold water would be a bit scary )
My drysuit has fabric 'socks' which are much bigger than my feet. It's not a huge problem but the socks are a little uncomforable when scrunched up inside my wet boots.
Any tips on how to get my feet comfy ? should the socks be tailored to fit my feet by drysuit magicians ?
Edited by Jumps - 28 Jun 19 at 8:13pm
The Moo View Drop Down
Post Options Post Options   Quote The Moo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 19 at 9:17pm
You normally get wetsuit boots 1 or 2 sizes too big to go over dry suit feet.
MerlinMags View Drop Down
Admin Group
Admin Group
Post Options Post Options   Quote MerlinMags Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 19 at 9:35pm
1. Wear normal socks inside the drysuit.
2. Pull the feet tight, even if that means your heel isn't on the heel of the drysuit perfectly.
3. Fill your wetboots with warm tap water before you try to push the drysuit feet in.
4. If you really cant get comfy, you can switch to ankle seals... but your feet will be cold and wet!
Sam.Spoons View Drop Down
Post Options Post Options   Quote Sam.Spoons Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 19 at 12:32am
Yup, big boots, thick socks inside the drysuit and you'll be surprised how quickly you forget that they felt uncomfortable when you first put them on.
Edited by Sam.Spoons - 29 Jun 19 at 12:07pm
Post Options Post Options   Quote Jumps Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 19 at 11:54am
Thanks All,
Will try thicker socks !!
