New Posts New Posts RSS Feed: Solo dinghy on car roof possible or not?
Rusty69 View Drop Down
Post Options Post Options   Quote Rusty69 Quote  Post ReplyReply Direct Link To This Post Topic: Solo dinghy on car roof possible or not?
    Posted: 20 Feb 19 at 9:01pm
I have a Europe dinghy which is a bit small for me, however it fits on the car roof, Citroën berlingo with mast and launch trolley. I can lift it on my own, but find help from wife makes it easier.
Now, i would like something a bit bigger, and have always liked the look of the solo dinghy. What are people's thoughts on whether it would also be car toppable with trolley and mast? I am thinking it may be a bit too much.
Any experience gratefully received.
Thanks
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 19 at 11:00pm
It's a fair bit bigger and heavier than the Europe. Car roof weight limits could be a problem. I'm not sure I could safely load one singlehanded either.
NickM99 View Drop Down
Post Options Post Options   Quote NickM99 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 19 at 3:54pm
The all up weight should be within the permissible roof loading of the Berlingo but it is going to be too heavy to get up and down alone.
Sam.Spoons View Drop Down
Post Options Post Options   Quote Sam.Spoons Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 19 at 6:53pm
10kg heavier than a Laser and 25kg heavier than a Europe. Probably easy enough for two to get up there but a challenge solo (pun intended) unless you are Geoff Capes.
Post Options Post Options   Quote Rusty69 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 19 at 9:30pm
Thanks all. So unlikely solo, but possible with two, even if one is a feable woman (ducks for cover)
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 19 at 9:52pm
I don't think I've ever seen a Solo roof racked, but plenty of Lasers and Moth variants. Before I made any decisions based on whether its practical or not I think I'd want to try it..
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 19 at 10:25pm
It wouldn’t be easy with the centreboard, the depth of the hull and the boom is not as easily removable as on a Laser (continuous outhaul attached to hull). Not to mention the mast isn’t two-piece so is longer than the car.
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 19 at 7:54am
Used to regularly put a Firefly on the roof of various cars. The Berlingo is short and high, though - not the best platform. Think car roofs have got a bit wimpy since, too. Tow bar seems easier?
Post Options Post Options   Quote Rusty69 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 19 at 7:55am
Good idea.
Post Options Post Options   Quote Rusty69 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 19 at 7:57am
There is some overhang with the Europe one piece mast. I guess the solo mast is longer. I can't remember the allowable overhang. 2m at back seems to ring a bell
