New Posts New Posts RSS Feed: rudder pintle
rudder pintle
Dangerousday View Drop Down
Post Options Post Options   Quote Dangerousday Quote  Post ReplyReply Direct Link To This Post Topic: rudder pintle
    Posted: 02 Jan 19 at 12:02pm
Any suggestions of how to re-attach the lower rudder pintle? (Claridge wood Phantom - self draining double floor)
One of the screws holding it in has half come out whilst sailing it yesterday. It's quite loose in the hole - I've tried retightening it, and theres not much 'bite'. Obvious answer is a bigger screw but it goes through the pintle and an alloy plate before going into the wood hull and I don't think theres a lot of clearance for anything a bigger diameter - longer perhaps, but is it likely there will be anymore wood for it to go into screw into beyond the existing 2" screw?
Would drilling it out much bigger, say 1/2", and epoxying a dowel in work?
Phantom 906
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 19 at 12:50pm
My preference would be to put a hatch in the floor and through bolt it. Might have to be two hatches, one each side of the centre spine if there is one. Good for ventilating the rot trap that a false floor on a wood boat provides.
Epoxying in a piece of wood ought to work though. I think I'd try simply filling the hole with a microfibre rich epoxy mix and drilling a new pilot hole first though as being a minimum effort first solution.
Post Options Post Options   Quote Dangerousday Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 19 at 1:03pm
Thanks. Think I'll give the epoxy mix a try first.
Doubt theres enough depth at transom to get a useful hatch in. Difference between inner and outer skins there isn't much more than the drain plugs that are in the transom.
Phantom 906
423zero View Drop Down
Post Options Post Options   Quote 423zero Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 19 at 1:05pm
Provided wood not rotten a slightly thicker screw would work, the Dowell would also work, not sure about your level of expertise so apologies in advance, you need to drill a pilot hole in Dowell, drill needs to be diameter of shaft of screw, easy way is to lie drill on top of screw and make sure you can see threads.
Sam.Spoons View Drop Down
Post Options Post Options   Quote Sam.Spoons Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 19 at 1:59pm
Or make a bigger alloy plate and add a screw each side?
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 19 at 5:27pm
In this context you only need enough depth to get a socket in to hold a nut on the end of the bolt, you don't need to be able to get a hand in there.
