New Posts New Posts RSS Feed: Deck grip
Deck grip
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: Deck grip
    Posted: 12 Nov 18 at 11:15am
Thinking of re-gripping the RS800... what has worked for people before?
Cloths (big square self adhesive sheets) or gel-coat with additives?
What brands have you used from where and how effective were they?
Have you had decks re-done professionally, who did it and how effective was it?
Post Options Post Options   Quote iGRF Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 18 at 12:02pm
You could cover it in jewels.. Snowboard traction wouldn't it look bling? ;-)
Jewel Drops
Although more seriously there was somebody on here quite recently talking of the actually supplier of the stuff that pro-grip use in their highly marked up product.
Or you could just wax it and go for the weight saving.
I'm having mine done at the moment pro grip unfortunately, just waiting for costings, they didn't take my jewel drops idea seriously either.
423zero View Drop Down
Online Status: Online
Post Options Post Options   Quote 423zero Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 18 at 1:21pm
I got 4" wide see through grip tape off eBay, hasn't lifted for 3 seasons, but if you kneel on it, it will graze your skin or worse damage your dry/wet suit, still feels like it did when I first rolled it on.
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 18 at 1:45pm
When applying the tape did you sand back existing gel-coat textured finish?
With both of us trapping no-one will should ever be sitting down on it, so happy for it to be pretty harsh on skin and suits.
Edited by mozzy - 12 Nov 18 at 1:49pm
Jack Sparrow View Drop Down
Post Options Post Options   Quote Jack Sparrow Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 18 at 3:12pm
Medical Prosthetic Supplies, EPA Foam - https://www.algeos.com/acatalog/comfortsheeting
Daniel Holman View Drop Down
Post Options Post Options   Quote Daniel Holman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 18 at 4:48pm
Wax looks filthy after a few races. Horrendous to remove afterwRds.
Eva peels off, looks shoddy even before it peels off And I think it soaks up a bit of water.
There are a few Options re gelcoat.
All would require you to mask off and sand back the worn non skid. Clean, prep etc.
You can thicken up oem gelcoat with silica and roller it on with mohair roller leaving anything up to 1970s ceiling artex texture to really rip your gear - itís how d zeros are done (they are not too aggressive) ie not moulded in non skid. You can sand back to taste if itís too aggresive.
I prefer thin gelcoat with Awlgrip griptex mixed in. Rollered on with foam roller. More like sandpaper finish. Less 1970s ceiling.
If super weight conscious you could prep the area down to perfect 400grit, then roll on clear durepox, shake griptex over from a big sugar / salt shaker, then wait for an hour do another coat of durepox.
Griptex is pricey but I have some if you need it.
Post Options Post Options   Quote 423zero Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 18 at 6:24pm
This is similar to stuff I bought
https://www.ebay.co.uk/itm/Anti-Slip-Tape-High-Grip-Non-Slip-Safety-Strip-Adhesive-Backed-Floor-Steps/253516294259?var=552701801813&hash=item3b06bfa873:g:b5kAAOSwoupatfg8
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 18 at 6:20am
Thanks, I think if we do the whole deck in anti-slip we'll need larger rectangles of the material. 4inch wide might be to narrow?
Dan, one of the worries of DIY is we'Ll be using the marine shed at HISC. How temperature sensitive is the gel coat?
Post Options Post Options   Quote Daniel Holman Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 18 at 11:02am
Mozzy,
Gel will go off whatever as long as itís not being rained on. You can up the catalyst beyond 2% but I wouldnít advise that as you have less working time on a big job. Since this is not a commercial repair just leave it a day!
That said a fan heater and crude tent will get it off fast.
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 18 at 10:38am
Cheers
So you sand back existing grip, do you go through to the material below or leave the gel coat (so the deck is still white)?
Then apply a thin layer of gel coat on top with the AWlgrip Griptex mixed in.
Is the grip text a dry or wet? Is it basically like a sandy substance you mix through the gel?
Do you use the extra coarse, coarse or fine stuff?
Edited by mozzy - 14 Nov 18 at 10:49am
