New Posts New Posts RSS Feed: stuck mast cap
stuck mast cap
llywelyn1984 View Drop Down
Post Options Post Options   Quote llywelyn1984 Quote  Post ReplyReply Direct Link To This Post Topic: stuck mast cap
    Posted: 10 Sep 18 at 2:00pm
my mast top cap is stuck on, and i want to take it off.
Any ideas?
Time Lord View Drop Down
Post Options Post Options   Quote Time Lord Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 18 at 2:31pm
You don't say on what type of boat is this mast. If its a dinghy then you can take the mast down easily, if not call a proper rigger!
On a dinghy mast, remove any screws holding the cap then if the cap fits outside the mast gently heat up the cap so that it expands away from the mast and should come loose. If the cap is inside then warm up the mast (assuming its ali).
If its a carbon mast, try the warming but only gently.
Merlin Rocket 3609
Post Options Post Options   Quote llywelyn1984 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 18 at 2:59pm
sorry it's on the topper topaz mast top section.
Post Options Post Options   Quote llywelyn1984 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 18 at 3:45pm
So heat up the aluminium with a small blow torch/heat gun?
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 18 at 6:45pm
Poke a very long stick down the inside and push it out.
Sam.Spoons View Drop Down
Post Options Post Options   Quote Sam.Spoons Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 18 at 8:57pm
Or drop a heavy piece of bar/tube into the bottom, even if itís not long enough you can bounce it up and down to hammer the top out
Capt_Fred View Drop Down
Post Options Post Options   Quote Capt_Fred Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 18 at 12:40pm
You can gently hit the aluminum rings using the hammer with plastic or rubber ends to avoid scratches and dents to loosen it up. Even if you damage it, it shouldn't be a problem to find a replacement. You can check them on https://www.boatid.com/sea-dog/ or simply visit amazon
Edited by Capt_Fred - 28 Sep 18 at 10:15am
Post Options Post Options   Quote llywelyn1984 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 18 at 1:06pm
thanks will have a go this weekend.
Post Options Post Options   Quote llywelyn1984 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 18 at 10:19am
rammed it out from the far end, needed a very long piece of metal/wood which wasn't sharp.
far end came out with a hammer and screwdriver.
