New Posts New Posts RSS Feed: Default series tie resolution
ClubRacer View Drop Down
Post Options Post Options   Quote ClubRacer Quote  Post ReplyReply Direct Link To This Post Topic: Default series tie resolution
    Posted: 15 Jul 18 at 11:19pm
If no series tie format is specified in the NOR/SI's does it mean you should default to the RRS ones?  aka
A8 SERIES TIES
A8.1 If there is a series-score tie between two or more boats, each boat’s race scores shall be listed in order of best to worst, and at the first point(s) where there is a difference the tie shall be broken in favour of the boat(s) with the best score(s). No excluded scores shall be used.
 A8.2 If a tie remains between two or more boats, they shall be ranked in order of their scores in the last race. Any remaining ties shall be broken by using the tied boats’ scores in the next-to-last race and so on until all ties are broken. These scores shall be used even if some of them are excluded scores.
Edited by ClubRacer - 15 Jul 18 at 11:19pm
Brass View Drop Down
Post Options Post Options   Quote Brass Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 18 at 2:59am
If your SI don't validly change the RRS you must comply with the RRS.
Why would you think you can, should, or need to do otherwise?
