Lower back issue - dinghy or keelboat? |
Post Reply | Page 123> |
pij27
Groupie Joined: 27 Jul 10 Location: Ryde / Tilbury Online Status: Offline Posts: 44 |
Topic: Lower back issue - dinghy or keelboat? Posted: 12 Mar 18 at 11:24am |
Just a question relating to peoples thoughts or experiences. I have a lower back problem caused from a car accident resulting in two damaged discs and occasional back spasms. I am looking at taking up sailing after a number of years, either in a dinghy or a small keelboat. My question is which would be better for me? Probably no simple answer, but any thoughts or guidance. Doctor told me not to try powerboats or off road driving due to possible shock loads.
Do Different
Post Options Quote Reply Posted: 12 Mar 18 at 12:32pm |
I know nothing of medical issues. However, although I currently sail trapeze dinghies if I wanted a simple and easy time with the safety net of some stability to limp home if I had an issue I would definitely go for a K1. I know a past wild man now of a few more years and he loves his, especially for a winter series; no falling over 😏
423zero
Post Options Quote Reply Posted: 12 Mar 18 at 1:26pm |
What launching facilities do you have ?
pij27
Post Options Quote Reply Posted: 12 Mar 18 at 1:57pm |
Not sorted out anything yet. Depends on whether look for dinghy or keelboat
jeffers
Post Options Quote Reply Posted: 12 Mar 18 at 2:42pm |
I would say dont go for anything that requires full on hiking dinghy wise.
It also depends on what sort of sailing you wish to do (cruising or racing). |
pij27
Post Options Quote Reply Posted: 12 Mar 18 at 3:58pm |
Would probably look at cruising as most racing seems to be lots of leaning and or hiking on a trapeze
423zero
Post Options Quote Reply Posted: 12 Mar 18 at 6:07pm |
inland or sea ?
You need to think about handling boat ashore, more likely to injure yourself handling boat ashore than sailing.
Sam.Spoons
Post Options Quote Reply Posted: 12 Mar 18 at 6:15pm |
Most dinghy racing does indeed require much hiking and effort, the physics is quite unescapable, the more righting moment you have the more power you can generate and the faster you will go. For cruising that doesn't matter as speed is not usually of the essence.
I have a slightly dodgy back and would probably not be happy racing a Laser, the Blaze is pretty kind to knees and backs but it is not a suitable boat for cruising. I'd suggest a sit in dinghy like an Enterprise, anything heavier is pretty much unmanageable singlehanded off the water (which you say you are considering in your other thread). or, provided you can use a vehicle to launch and recover, a small keelboat. You'll need a winch on the trailer too and a slip you can use for a vehicle launch to have any chance of managing it alone (my mate with the Stratos Keel manages fine on his own.)
Rupert
Post Options Quote Reply Posted: 12 Mar 18 at 7:15pm |
Get a sailing bag with wheels and a dolly wheel on the front of the trolley. It was the lifting my back spasmed over. Otherwise, get a boat with some depth to the cockpit, and one which you can perch on the deck and still keep it upright, rather than having to always hike.
For a single-handed boat, I've found the Lightning 368 ideal. Old-fashioned double handed boats tend to behave well, and reefing is always an option. Only get a keelboat if you don't have to take it off the water every time, I'd say. The K1 is small enough, but you'd need a team for the Stratos or Venture keels. |
Wiclif
Groupie Joined: 04 Oct 05 Location: United Kingdom Online Status: Offline Posts: 79 |
Post Options Quote Reply Posted: 12 Mar 18 at 7:51pm |
All back problems are different. I had a back operation back in the year 2000. Some days are ok and some when I wake up the next morning my back says “you shouldn’t have done that yesterday”
I have stuck to dinghies - or nearly, I currently own and enjoy a K1. I have tended to avoid bigger keelboats as the loads are a lot higher. You are as likely to have back problems with the rigging or launching of any boat as when actually sailing. If you sail the same class of boat as others at the club then you are more likely to get help when launching or recovering the boat. |
