New Posts New Posts RSS Feed: High Points Scoring System - Tie Break Ideas
sargesail View Drop Down
Post Options Post Options   Quote sargesail Quote  Post ReplyReply Direct Link To This Post Topic: High Points Scoring System - Tie Break Ideas
    Posted: 23 Jan 18 at 9:03pm
Anyone got any ideas for how to break ties in a High Points Scored system - that is where the winning boat scores number of entries, second scores number of entries minus one and so on?
Brass View Drop Down
Post Options Post Options   Quote Brass Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 18 at 9:49pm
Rule A8.1 should work.  It's phrased to apply equally to high or low points systems.
That's what this says
http://www.ussailing.org/wp-content/uploads/DARoot/Race%20Admin/Racing%20Rules/Documents/Scoring%20a%20Long%20Series.pdf
Better to move to standard Appendix A Low Points.
If you must use High Points, make sure that your base figure N, is sufficiently bigger than the number of original entrants to accommodate additional entrants.
MikeBz View Drop Down
Post Options Post Options   Quote MikeBz Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 18 at 3:27pm
If 'winning boat scores number of entries' means 'number of entries in that race' (not number of series entries) then surely the comment about the base figure N is irrelevant.  In this case you could argue that on a tie-break 3 x 1st places in races with 2 entries are 'worth' less than 3 x 1st places in races with 20 entries - I'm guessing this is what Matt is getting at?  I would suggest when breaking the tie with the number of 1st/2nd/3rd places you tot up the points earned for 1st places and compare those - if they are still tied then tot up points gained for 2nd places etc.
