Hull Repair? |
Snips
Newbie Joined: 15 Jan 18 Online Status: Offline Posts: 4 |
Topic: Hull Repair? Posted: 15 Jan 18 at 12:52pm |
Hi
I have a byte CII that I haven't used in a while and after a long time sat on its trailer looks like its settled and taken damage. Its formed a crack that's gone right through the GRP just under the gunwhale and the surrounding GRP is now soft IE it gives when you apply pressure. Has anyone seen similar damage and it been repaired or is it really bad news? Thanks
Snips
Post Options Quote Reply Posted: 15 Jan 18 at 12:59pm |
https://www.amazon.co.uk/clouddrive/share/HLq3wnKRkCgl15VUqkX010eB59ynW6Gh3bckuRvfVp6
https://www.amazon.co.uk/clouddrive/share/0o1HXLWMIADsoCDKacxPgyBofP2CTwSFRID7JRU2YMe https://www.amazon.co.uk/clouddrive/share/itnp93zNUtdUU51fTVliR4Eb2bZbLEOW31nOjDHS8OO
423zero
Post Options Quote Reply Posted: 15 Jan 18 at 10:06pm |
I would remove gelcoat from area and re-lay new fibre glass matting, then fair out to existing hull using gel coat or body filler (depending on age of boat).
zippyRN
Far too distracted from work Joined: 14 Sep 06 Online Status: Offline Posts: 437 |
Post Options Quote Reply Posted: 17 Jan 18 at 1:25am |
first course of action
get it 'indoors' and dry ( ideally somewhere warm- ish and dry - doesn;t have to be room temp and bone dry but obviously that is going to be better ) but gettign it somewhere dry is a start remove any loose gelcoat / explore around the crack to see if there is delamination and /or the gelcost seperating - if so you need to get that off to help dry out the underlying laminate |
Snips
Post Options Quote Reply Posted: 19 Jan 18 at 6:48pm |
Thanks for the reply zippy and zero.
