How wide is to wide ? |
Scooby_simon
Really should get out more Joined: 02 Apr 04 Location: United Kingdom Online Status: Offline Posts: 2415 |
Topic: How wide is to wide ? Posted: 21 Oct 05 at 1:41pm |
How wide would you like your cat to be (if towing was not an issue) 1/2 the length is the old Rule-of-thumb. I am thinking wider might be better if you have a kite as it gives you some lift. What do you thing ?
Edited by Scooby_simon |
Tornado_ALIVE
Really should get out more Joined: 07 Nov 04 Location: Australia Online Status: Offline Posts: 611 |
Post Options Quote Reply Posted: 21 Oct 05 at 4:05pm |
Gives some lift but also ability to drive harder...... Safer to stick with 12 LOA rule
Scooby_simon
Post Options Quote Reply Posted: 21 Oct 05 at 11:23pm |
I assume you mean 1/2 LOA But what about with the addition of T foil rudders ? Seriously thinking about making the new boat 10 feet wide...... |
Chris Noble
Really should get out more Joined: 26 Nov 04 Location: Scotland Online Status: Offline Posts: 710 |
Post Options Quote Reply Posted: 23 Oct 05 at 10:57am |
what did you mean by it gives some lift?
Scooby_simon
Post Options Quote Reply Posted: 23 Oct 05 at 2:29pm |
When the kite is flying it gives some lift.
Tornado_ALIVE
Post Options Quote Reply Posted: 24 Oct 05 at 1:43pm |
Some but not much...... Kite is very flat compared to skiff kites. T foil rudders are slow when fixed and your trim is not right. On the I14s I sailed on the T foils were adjustable. I believe though, that foils to change the pitch of a boat causes excessive drag. Best to practice correct big breeze trapezing techniques and driving. If you are forced to use foils to maintain the pitch of a boat, the boat has some manufactured problems ie beam to wide or too much power for, fore aft righting momentem. |
Scooby_simon
Post Options Quote Reply Posted: 24 Oct 05 at 6:22pm |
Stephen,
I don't agree.
The one thing that slows cats down is having to ease off becasue you have run out of bow. Yes T's do add a little drag (or a lot if they are set wrong). But if they allow you to press harder (after you have "Best to practice correct big breeze trapezing techniques and driving") then you will be able to go faster down wind.
I've yet to sail a T-foiul boat, but judging from what people say they love them and they allow you to drive harder (and so faster) down wind.
Jalani
Posting king Joined: 03 May 05 Location: Great Britain Online Status: Offline Posts: 164 |
Post Options Quote Reply Posted: 24 Oct 05 at 9:27pm |
What T foils DO allow you to do is drive off really hard in a gust without burying (or not burying much) and therefore being able to gain lots of distance to leeward at speed. The boat becomes very responsive without the rudders losing 'grip' and the foils hold the bows up when they would normally dive.
Tornado_ALIVE
Post Options Quote Reply Posted: 25 Oct 05 at 2:34pm |
Drive harder does not necessarily mean faster...... More load on the rig / platfrom plus more drag. More power sailing like Hobie 18 compared to efficiency like an A Class. This is just my personal opinion which is based on no real research other than boats I have sailed before and how they felt to me. Therefore I may be wrong, but have the manufactures using these rudders actually tank tested them. And why don't you see them in other development classes including the C Class which is at the forefront of technology. I would love to take an F16 without foils downwind (and around the course) in a variety of wind strenghts / sea state against an F16 with foils and compare boat speed. This I hope would answer some questions. I personaly question weather T foils are benificial. I also believe you can settle a boat and drive a boat hard (and faster) through improved sailing techneques and reading what the boat is and will do, earlier. In summary, I do believe T foils would help reduce pitching a little, but the resulting drag and compramised performance when the T foils are not needed would far out weigh any small benifit they may have. |
Jalani
Post Options Quote Reply Posted: 25 Oct 05 at 3:01pm |
I agree with you Stephen, the T foils do create some additional drag. However, whilst this is a problem in low wind speeds (2 - 10 knots), I do feel that the benefits vastly outweigh the disadvantages in 12 knots plus. The answer: two sets of rudders! Seriously, having experienced T foils, I'd not go back. Sailing downwind with them, in a blow, fully powered up with the kite pulling is just so fantastic! You can't help but get off the boat with a great big cheesy grin at the ride you've just had whilst everyone else has been down the mine and broken stuff! |
