New Posts New Posts RSS Feed: Sailing with no keel!
NickA View Drop Down
Post Options Post Options   Quote NickA Quote  Post ReplyReply Direct Link To This Post Topic: Sailing with no keel!
    Posted: 30 Jan 13 at 8:07pm
So, M. JP Dick is completing the Vendee Globe in a keel boat that has no keel on it.  HOW on earth would you manage that.
It sounds like sailing a high powered dinghy (an RS800 say) with the crew and helm sitting on the centre line.  Running deep down wind with no gusts, I can see it might be possible, but what happens up wind?
I know he has water ballast - but how much righting motion does that provide.
As a dinghy sailor who occasionally charters the odd (non planing) lead mine for a holiday ... it sounds quite mad to me.  Confused ..... but he's still upright!
3604 ...lapse of reason
Javelin 558
Online Status: Online
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 13 at 9:08pm
At least he has daggerboards to stop the leeway.  I'm sure I'd not want to be trying, but he did comment that upwind was easier than off wind. Not sure why, though.
Mister Nick View Drop Down
Post Options Post Options   Quote Mister Nick Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 13 at 9:59pm
Well he's got the daggerboards to stop him falling sideways too fast. I'm guessing that the boats were designed to deal with keel failure to some extent and therefore are able to sail on without it, albeit fairly slowly and conservatively. I guess it's because you've got so many sail options on a boat like this aswell. You can reef the main right down to practically nothing, you've got access to some really tiny headsails for when it gets nasty etc. So I'm guessing that's how he's managing it.
Mark Jardine View Drop Down
Admin Group
Admin Group
Post Options Post Options   Quote Mark Jardine Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 13 at 6:46am
The latest from JP here - http://www.yachtsandyachting.com/news/167752/Spanish-stopover-before-Les-Sables-dOlonne
He's taking a stopover to shelter from the Biscay gale, but now only has 350 miles to the finish! This will be a remarkable achievement if he makes it.
All the best JP!
olly_love View Drop Down
Post Options Post Options   Quote olly_love Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 13 at 8:33am
water balast counts for alot of the RM,
he has about 5 tonnes of it so almost doubling his displacement,
its also positioned well outboard and aft/fwd(depending on what he needs)
so it makes a massive difference,
TWO FRANK-Hunter Impala
Rockhopper View Drop Down
Post Options Post Options   Quote Rockhopper Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 13 at 7:50pm
Well said i do hope he makes i too best of luck to him
Retired now after 35 seasons in a row and time for a rest
Post Options Post Options   Quote NickA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 13 at 7:43pm
Amazing, he's home.  There was a comment on the vendee globe site that if he let it heel more than 30 degrees then it would fall over.  I guess 30 degrees is quite a lot in a keel boat, but not when it has no keel.
Yes the water ballast has to help, especially as the hull is somewhat scow shaped, ie the windward side lifts rather than the whole hull rotating about some point below decks.
Anyway ... what an achievement!
Javelin 558
ifoxwell View Drop Down
Post Options Post Options   Quote ifoxwell Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 13 at 11:23am
I agree. Lets also not forget its easy to make judgments sitting comfortably on land... quite another when your alone, miles from any where when arguably the most important part of your boat falls off.
N12 3441
ASok View Drop Down
Post Options Post Options   Quote ASok Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 13 at 1:12pm
It is an amazing achievement and really shows what these sailors are capable of.
The whole race has been amazing to follow. I hope they reconsider the rules for the next cycle and start building keels to last. I'm definitely in the camp that a keel should be a permanent fixture for the entire life of the boat, not just certain mileage.
