maintain carbon mast |
AJ 348
Newbie Joined: 23 Feb 12 Location: essex Online Status: Offline Posts: 12 |
Topic: maintain carbon mast Posted: 23 Feb 12 at 9:04pm |
Hi all - newbie here.
I did try and search for an answer for my post (honest) but failed. So firstly, sorry if this has been asked 100 times before.
RS600 owner and I'd like to do a bit of maintenance on the boat before spring. Does anyone know the best way to tidy-up a carbon mast. I had heard you simply rub them down with sand paper and apply a new coat of varnish ?? just want the boat to look a little better this summer. TBH I spend more time up-side-dwon so I should tidy up the hull
Thanks for any help
AJ
Neptune
Really should get out more Joined: 08 Jun 09 Location: Berkshire United Kingdom Online Status: Offline Posts: 1313 |
Post Options Quote Reply Posted: 23 Feb 12 at 9:42pm |
Wet and dry don't dry sand.
International two pot seems to last well once its done. |
Musto Skiff and Solo sailor
Post Options Quote Reply Posted: 23 Feb 12 at 10:34pm |
Personally I reckon that if varnish provided really good UV protection it wouldn't peel off as often as it does. So I paint my masts in something light coloured rather than varnish. I suggest something like 320 grit wet and dry, and use it wet if for no other reason than it lasts better. Use lukewarm water and put a dash of washing up liquid in it. Try and remove everything loose but the absolute minimum of actual fibre.
Jack Sparrow
Really should get out more Joined: 08 Feb 05 Location: United Kingdom Online Status: Offline Posts: 2965 |
Post Options Quote Reply Posted: 24 Feb 12 at 1:48pm |
paint's cheaper too. I now have a mast sock and don't worry about either.
Neptune
Post Options Quote Reply Posted: 24 Feb 12 at 1:51pm |
But your boat also lives in its own personal shed on wheels Jack!
Jack Sparrow
alstorer
Really should get out more Joined: 02 Aug 07 Location: Cambridge Online Status: Offline Posts: 2899 |
Post Options Quote Reply Posted: 24 Feb 12 at 3:30pm |
with paint, you can go for a pimp colour to match or contrast the hull |
Al |
AJ 348
Post Options Quote Reply Posted: 24 Feb 12 at 3:43pm |
hmmm ... I could paint it Blackwater Muddy Brown - the top's normally that colour anyway
what type of paint chaps ? I assume it needs to be pretty flexible as the RS mast is raked right back under tenison. cheers |
Post Options Quote Reply Posted: 24 Feb 12 at 4:11pm |
I usually use two pot polyurethane.
Rockhopper
Really should get out more Joined: 16 Nov 07 Location: Eastry Online Status: Offline Posts: 642 |
Post Options Quote Reply Posted: 24 Feb 12 at 7:23pm |
I have just done my 600 mast so know the problems i found that most of my varnish was very loose so i got one of those window blades with the stanle knive edge and just went along very carefully and got the whole lot off Then i used some very fine wet and dry again it was hard going but worth it in the end and it looks like new now
