New Posts New Posts RSS Feed: sailvave  scor
sailvave scor
semy View Drop Down
Post Options Post Options   Quote semy Quote  Post ReplyReply Direct Link To This Post Topic: sailvave scor
    Posted: 13 Oct 11 at 3:29pm
hi
I can optimist-laser scor
but I don't know yacht scor
ples help me (seconds ,minutes)
thank you
semy
SUGmeister View Drop Down
Sailwave Moderators
Sailwave Moderators
Post Options Post Options   Quote SUGmeister Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 11 at 4:16pm
Originally posted by semy
hi
thank you
semy
I think you should go visit http://sailwave.com/support/support.php to start with!
< ="-" ="text/; =utf-8">
Simon SUGmeister
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 11 at 4:27pm
Semy, I can't tell from your post what your problem is. Sailwave will do pretty much most stuff when you get to grips with it, but it can take a little bit of tinkering. Almost everything about entering results is easier if you use the wizard thing tho', I'll tell you that much!
craiggo View Drop Down
Post Options Post Options   Quote craiggo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 11 at 8:27pm
In sailwave, all that matters is the start and finish times, number of laps and handicap number.
I'm guessing when you say you can score lasers, you are probably scoring them as a fleet, therefore 1st, 2nd etc. as they finish, so you haven't been using the times.
For yachts they all have different handicap numbers. You need to identify what handicap scheme you are using, PY, IRC etc. Select the appropriate system in the scoring properties tab and for each competitor enter a handicap. Enter the race times and press score. Job done!!!!
