New Posts New Posts RSS Feed: Trapeze Systems
Trapeze Systems
29er1490 View Drop Down
Post Options Post Options   Quote 29er1490 Quote  Post ReplyReply Direct Link To This Post Topic: Trapeze Systems
    Posted: 19 Sep 11 at 6:03pm
I've noticed that a few 29ers are now switching from 2:1 trapeze adjustment down to 1:1 as there is less rope and therefore less hassle without much more physical strain on me, the crew.  I have tried to figure out a way of rigging the rope but I can't find a system that seems to run smoothly  Cry
Any help would be awesome  Big smile
Cheers.
themeaningoflife View Drop Down
Post Options Post Options   Quote themeaningoflife Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 11 at 6:41pm
The rope is spliced onto the block of the trapeze ring, then led up over the block in the clamcleat. You can then just tie a knot in the end as your lowest range. We found that having a very thin line in a couple of loops from from the hole in the bottom of the clamcleat around the rope that comes under strain is also really useful because it stops the cleat flopping about so much.
Just a word of warning, before you go splicing things on try the system with a bowline instead as unless your crew finds it very easy to pull themselves up and down you will not get any performance benefit due to the amount of energy being used raising and lowering.
Hope this is clear enough, if not just ask and I will try to clarify it Smile Seb
Cambridge University Lightweight Rowing Club
RS800 1128
kindly sponsored by RWO Marine
Post Options Post Options   Quote 29er1490 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 11 at 6:14pm
Ok I've tried it with a bowline and I think I need to hench up a bit first before I switch but now I know how at least! Thanks  Smile
Post Options Post Options   Quote themeaningoflife Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 11 at 6:35pm
No problem, any more questions feel free to ask  Smile
RS800 1128
