RWO UJ |
Jaws
Groupie Joined: 27 Nov 10 Online Status: Offline Posts: 92 |
Topic: RWO UJ Posted: 12 May 11 at 10:12pm |
I've just got a standard omniflex joint to replace the identical older one that was close to breaking. I'm now having an issue getting the thing into the socket. I've tried hammering, forcing etc. Are there any secret tricks to get it in there? I could file it, but that might affect how well it stays in, or perhaps heat it up to soften it?
Thanks
RS600 794
GybeFunny
Far too distracted from work Joined: 27 Oct 09 Online Status: Offline Posts: 403 |
Post Options Quote Reply Posted: 12 May 11 at 10:16pm |
Do you mean fitting it to the tiller or getting the new joint inside the tiller extension?
Jaws
Post Options Quote Reply Posted: 12 May 11 at 10:35pm |
Getting it inside the extension.
RS600 794
GybeFunny
Post Options Quote Reply Posted: 12 May 11 at 10:45pm |
In that case I put a bit of washing up liquid inside the tube and twisted the new extension in when I last did it.
Jaws
Post Options Quote Reply Posted: 12 May 11 at 10:51pm |
I'll try that tomorrow. Thanks
RS600 794
tim grasse
Newbie Joined: 01 Feb 10 Location: United Kingdom Online Status: Offline Posts: 34 |
Post Options Quote Reply Posted: 14 Jun 11 at 10:23pm |
if its an allyminium teller extension you could heat the end of it up with a blow torch and freexe the uk with ice, this will make the tube wider and the uj marginally smaller causing a looser fit then when they return to room temperature you have a very tight fit and if you want tighter you could always add a rivet but this method only works with an alloy tiller extension as the fire would destroy a carbon tiller extension.
