New Posts New Posts RSS Feed: moth tuning
moth tuning
winging it View Drop Down
Post Options Post Options   Quote winging it Quote  Post ReplyReply Direct Link To This Post Topic: moth tuning
    Posted: 16 Feb 11 at 7:26pm
Does anyone have any advice/knowledge they could pass on about setting up the probably magnum V moth?  It has the original Needlespar mast and Claridge boom, and a mainsail with this logo on it:
interestingly it also has a smaller moth logo near the clew.
Any tips on how to launch the thing would also be well received.
thanks,
Nessa
Post Options Post Options   Quote aardvark_issues Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 11 at 9:00pm
Worth an email to the moth mailing list as there are still a few old time mothies around who can probably help with specific stuff.
General thoughts on new mothing (bearing in mind this in the late 90's and a Magnum 8, your mileage may vary). Find a load of EPP swimming pool noodle floats and stuff them inside the tramps on the wing edges. 3 a side would be nice. This will help give you a bit of leeway when you dip a wing.
don't bother going out if it's light (sub 5 knots) or in over 12-15. life gets hard at these points.
try to get foils in and down before you get in the boat will make it much more stable - perhaps even launch it on its side and start capsized - also start with a bit of kicker on so there is some power to lean on.
Most peoples first goes in Moths ends with them running all over the place trying to keep it upright - try to get a bit of power in the main and lean into it, moving the sheet to keep you upright and moving.
good luck!
I luv Wight View Drop Down
Post Options Post Options   Quote I luv Wight Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 11 at 9:41pm
The logo is Richard Hargreaves Sails.
My first moth was a Magnum 3, which is much wider at the stern
Note the cool motorcycling suit  Cool
And first time out -
I did a tack to point it back in before capsizing - much skill  Wink
And being me... I just had to chop it - to the same transom shape as the Magnum 6 ( the fastest design at the time ) - it greatly improved the performance, less nosedives and faster, but then of course the good guys were on to the Magnum 8, and I remember being lapped at Hythe Euros in 1987 - Just ask Grumpfs - he was race officer!
Andy P
foiling Int Moth GBR3467
Freedom 21 Codling
