How to get a trailer tire to reseat? |
ifoxwell
Really should get out more Joined: 05 Jan 06 Location: Hoo Online Status: Offline Posts: 669 |
Topic: How to get a trailer tire to reseat? Posted: 07 Sep 10 at 3:20pm |
Ok not your normal technique question...
Being a cheap skate I have swapped a good tire from one wheel to another (that fits my trailer) but I'm having trouble now getting it to inflate. Its a standard tubeless tire and even with a garage airline I cant make a good enough seal on the rim to inflate it. Does any one have any handy tips on getting round this problem? Cheers Ian |
RS300
Guests
Guest Group |
Post Options Quote Reply Posted: 07 Sep 10 at 3:45pm |
Lukepiewalker
Really should get out more Joined: 24 May 06 Location: United Kingdom Online Status: Offline Posts: 1340 |
Post Options Quote Reply Posted: 08 Sep 10 at 7:42am |
I did one recently with perseverance and a garage airline. The key was to try and squish it approximately into shape so there weren't any large gaps twixt bead and rim.
Ex-Finn GBR533 "Pie Hard"
Merlinboy
Really should get out more Joined: 03 Jul 06 Location: United Kingdom Online Status: Offline Posts: 3169 |
Post Options Quote Reply Posted: 08 Sep 10 at 8:29am |
The fire trick is an old one and will work. Just use some wd40 and have a high preasure air hose near by, as the tyre will try and pop off as the fire contracts. I have not done it myself but the old man has. The other option is to take it to our local yre fitters and ask them to do it for you, but at "£20 a wheel it hardly seems worth the £10 to get them to do it!!
Edited by Merlinboy - 08 Sep 10 at 8:30am |
ifoxwell
Post Options Quote Reply Posted: 08 Sep 10 at 9:09am |
Got it done last night.
First I tried putting a ratchet strap around it to squish it to the wheel but as the tire has a very soft carcase and the rubber grips the strap this just deformed it. Then I thought sod it, i'll give the blowing it up option a go. I tired to do it with an aerosol can of light fluid but it just burnt rather than explode Next i tried it with a small quantity of petrol but this had the same result result. How ever the tire was warming up nicely so I put a normal cargo strap around it to squish it to the wheel and tried again, this time with success. So what did i learn.... really just that its perseverance, and a good head of hair such that you can pull some of it out that really matters. Ian |
RS300
Guests
Guest Group |
Post Options Quote Reply Posted: 08 Sep 10 at 9:39am |
Seriously thinking about inner tubes for mine. The tyre goes down randomly and I'm sure it's the seal. I think the pros use some kind of sealing paste.
didlydon
Far too distracted from work Joined: 15 Oct 08 Location: Margate England Online Status: Offline Posts: 280 |
Post Options Quote Reply Posted: 08 Sep 10 at 4:55pm |
Put a tube in it! A sure fire fix!
Vareo 365
les5269
Really should get out more Joined: 11 Oct 05 Location: United Kingdom Online Status: Offline Posts: 1530 |
Post Options Quote Reply Posted: 13 Sep 10 at 8:47pm |
Funny I was going to suggest this.
ncollingridge
Newbie Joined: 22 May 11 Location: Knebworth UK Online Status: Offline Posts: 3 |
Post Options Quote Reply Posted: 22 May 11 at 11:46pm |
And you can pick up tubes on ebay for not very much at all.
patj
Really should get out more Joined: 16 Jul 04 Location: Wiltshire Online Status: Offline Posts: 640 |
Post Options Quote Reply Posted: 23 May 11 at 7:02pm |
Local tyre fitters charged us £4 for fitting two tyres to rims last week. But we do buy all our car and van tyres there.
Edited by patj - 23 May 11 at 7:03pm |
