Epoxy mixes |
zailor
Far too distracted from work Joined: 10 May 09 Location: Penparc Online Status: Offline Posts: 249 |
Topic: Epoxy mixes Posted: 18 May 10 at 5:28pm |
Hi I have some of those powders you put into epoxy to make it so more magical things! Thanks |
Post Options Quote Reply Posted: 18 May 10 at 5:49pm |
Silica - thicker/thixotropic, brittle
Microfibres - stronger, flexible microballoons and similar - lighter and, since you use less epoxy, probably cheaper |
zailor
Post Options Quote Reply Posted: 18 May 10 at 5:57pm |
so Im guessing I was right using silica for the dager board so its strong but brittle but I wont want flex And microballons, filling holes? |
alstorer
Really should get out more Joined: 02 Aug 07 Location: Cambridge Online Status: Offline Posts: 2899 |
Post Options Quote Reply Posted: 18 May 10 at 7:15pm |
by lighter he means less dense, yes- microballoons are hollow glass spheres.
silica does help make the finished resin harder, but in formulation tends to come into it's own in viscosity control- important more for un-cured properties, such as the ability to mix properly when pumped through a "static" mixer. |
Al |
Rupert
Post Options Quote Reply Posted: 18 May 10 at 8:20pm |
The silica is the most difficult to sand back after, too, which may affect where you use it.
zailor
Post Options Quote Reply Posted: 18 May 10 at 8:37pm |
yes I found that out when I used it on my dagger board, I used the massive blob then sand down technique.
So last question, would I use the micro fibres/ballons to get the right viscosity or add sillica to the epoxy/balloon/fibres mix? |
