600 racks |
Post Reply | Page 12> |
dics
Far too distracted from work Joined: 05 Oct 05 Online Status: Offline Posts: 317 |
Topic: 600 racks Posted: 01 Mar 10 at 3:05pm |
I am sure this has been asked before but I can not find the postings. Has anyone changed the racks on a RS600 from wide to narrow? If so it is an easy job and are they easy to come by in the secondhand market? Thanks Rich |
RS600653
Newbie Joined: 30 Nov 09 Online Status: Offline Posts: 12 |
Post Options Quote Reply Posted: 01 Mar 10 at 3:29pm | |
I've been trying to find some narrow racks for a while now but nothing seems to have appeared so I'm going to start off with the wides. As far as changing it goes it's pretty easy to do, you'll just have to adjust the lengths of your control lines assuming that they're continuous. When I took my racks off I found they were stuck but, after a bit of gentle persuasion they came off with the plugs. To refit them I've rotated the plugs about 45 degrees (to avoid the old screw holes that I've filled) and drilled some new holes and screwed them back on with the appropriate amounts of silicon sealant. Andy Edited by RS600653 |
Rupert
Post Options Quote Reply Posted: 02 Mar 10 at 8:33pm | |
So you can't just cut the ends off wide racks to make them narrow?!
Andrewst
Posting king Joined: 14 Aug 05 Location: United Kingdom Online Status: Offline Posts: 129 |
Post Options Quote Reply Posted: 02 Mar 10 at 9:05pm | |
Its not that simple as it changes the geometry. I changed mine from wide to narrow and its a bitch to do. A mallet and block of wood to bash them off, then you will need new end bungs to re attatch to the hull ready for the new wings.
dics
Post Options Quote Reply Posted: 03 Mar 10 at 8:42am | |
Thanks guys.
mike ellis
Really should get out more Joined: 30 Dec 05 Location: United Kingdom Online Status: Offline Posts: 2339 |
Post Options Quote Reply Posted: 14 Mar 10 at 9:26pm | |
I didn't need new bung ends when I swapped my racks. I can't see why you would. Sledge hammer and a block of wood to remove them is definately the way to go.
Also International 14, 1318 |
Webmuppet
Really should get out more Joined: 11 Mar 06 Location: Suffolk Online Status: Offline Posts: 534 |
Post Options Quote Reply Posted: 14 Mar 10 at 9:58pm | |
I remember watching somebody use that method - I'm not suggesting an easier way, but it did loosen an awful lot of gel-coat where the inner part of the racks touch the hull - this was on a yellow hull and colour matching it afterwards was a bit of a nightmare, Nigel |
Graduate 2530 'Galaxy' |
s.a.l.t.y
Really should get out more Joined: 11 Apr 08 Location: Costa del Essex Online Status: Offline Posts: 517 |
Post Options Quote Reply Posted: 14 Mar 10 at 10:17pm | |
You have to knock the back end of the racks gently outwards first until the tube comes off the plug. Then twist the rack around the axis of the front plug (so you dont bend anything) and they should come off really easy.
mike ellis
Post Options Quote Reply Posted: 17 Mar 10 at 7:07pm | |
Just to clarify, I meant sledge hammer and wood to remove the racks. I recommend the more delicate screwdriver method if you need to remove the plugs. |
RS400atC
Post Options Quote Reply Posted: 18 Mar 10 at 8:43am | |
You may find the plugs stick in the ends of the tubes and their screws pull out of the hull. You then need to hold the screws in a vice while pulling/levering/hammering the wing away. It's awkward. In salt water, the alloy tube corrodes and binds to the plug. New plugs are about 8 quid each iirc. I managed to re-use 3 out of 4. When re-assembling, use silicone grease or some other favourite gunge between the plug and the tube. Also isolate the alloy tube from the stainless u-bolts at the gunwhale. Tape, plastic, whatever. I would think trying to bend wide racks to make them narrow, i.e. pulling the front tube forward will stress the welded joints and failure will follow in due course. I think this is doomed, the angle is probably the same, but the fore and aft tube is shorter on a wide wing???? Wings have been swapped on the 600 Yahoo group, but narrow ones are probably more in demand. However at 200quid a side, it's worth asking. At these prices, I can see a lot of people being out of class. |
