Centreboard pivot |
Bikali
Newbie Joined: 11 Apr 05 Location: United Kingdom Online Status: Offline Posts: 2 |
Topic: Centreboard pivot Posted: 11 Apr 05 at 11:40pm |
Hi, I'm just renovating an old Phantom dinghy and am suprised by the centreboard pivot ... it pivots on a M6 bolt through the casing; but the hole in the board is 25mm dia. This seems wrong am I missing a bush or should I fill with epoxy (... doesn't sound good) and drill a clearance hole for the 6mm bolt? Thanks for any help Alistair |
Fires don't just start they need help ...
ChrisJ
Far too distracted from work Joined: 07 May 04 Location: United Kingdom Online Status: Offline Posts: 337 |
Post Options Quote Reply Posted: 12 Apr 05 at 8:29am |
The bolt will need to fit the hole through the centreboard casing. It must be a pretty tight fit, otherwise you get leaks all the time through the bolt hole. Then, you need to make the hole in the board match the bolt size. This can be done by filling with epoxy and drilling out. At one time (as far as I can recall) the Phantom used fireball parts - maybe they have a class rule of a larger bolt, while the phantoms allow narrower bolts? |
Bikali
Post Options Quote Reply Posted: 12 Apr 05 at 10:35pm |
Thanks for the info the case does have an M6 hole so its just the filling on the board I need to do ... should be simple Thanks Alistair |
