Laser 2 question |
JohnRs400
Newbie Joined: 30 Mar 05 Location: Switzerland Online Status: Offline Posts: 10 |
Topic: Laser 2 question Posted: 30 Mar 05 at 5:22pm |
Hi
I need to replace the small twin block on the bow of a laser 2 used for the spinaker. All the ones I find can not be mounted flat. Does anyone know who makes/sells them and there part number. Many thanks in advance. John |
49erGBR735HSC
Really should get out more Joined: 30 Mar 05 Location: United Kingdom Online Status: Offline Posts: 1991 |
Post Options Quote Reply Posted: 03 Apr 05 at 11:25pm |
It might be worth trying the Laser Centre and giving them a description of the block, they should carry them in stock.
Granite
Far too distracted from work Joined: 12 May 04 Location: Scotland Online Status: Offline Posts: 476 |
Post Options Quote Reply Posted: 04 Apr 05 at 1:41pm |
I think you want an RWO plain bearing 18mm double block.
You take the pin and shackle out of the top and put a screw down through the hole left and also a screw through the center of the hollow rivet that the blocks rotate around. It is a bit gash but I think that is how Laser did it, I do not think they used the blackplastic spacers but they might be a good idea. |
JohnRs400
Post Options Quote Reply Posted: 04 Apr 05 at 2:43pm |
It's a ronstan RF662 Double block tube rivet. Many thanks for all the help |
