Question about new boat |
timmyg
Newbie Joined: 25 Feb 09 Online Status: Offline Posts: 2 |
Topic: Question about new boat Posted: 25 Feb 09 at 2:02pm |
Hi all! Sorry, this is going to be a very obvious question! I recently bought an old firefly, which is my first centreboard boat (always used daggerboards like topper etc). First time I capsized the board dropped back into the hull (as might be expected) but then fell off entirely as its attached with a slot in the centreboard rather than just a hole with a bolt through. Obviously I didn't lose it as it was still attached to the boat but I couldn't right the boat with no board to get leverage on. What can I do to prevent it dropping without tying it down, which would cause damage in the event of grounding.... Thanks for the help Timmy |
Jack Sparrow
Really should get out more Joined: 08 Feb 05 Location: United Kingdom Online Status: Offline Posts: 2965 |
Post Options Quote Reply Posted: 25 Feb 09 at 2:13pm |
use a releasable cam cleat to hold it down. If you hit the putty it will release without to much damage.
link |
timmyg
Post Options Quote Reply Posted: 25 Feb 09 at 2:32pm |
Awesome - looks just like what I need! Thanks for that Timmy |
Andymac
Really should get out more Joined: 04 Apr 07 Location: Derbyshire Online Status: Offline Posts: 852 |
Post Options Quote Reply Posted: 25 Feb 09 at 4:45pm |
I have also just recently bought an older Firefly, fitted with an alloy plate. Many people are probably not aware of the potential problems; i)The centreplate dropping back into its slot under its own weight during a capsize. ii)The centreplate (if slotted) dropping out of its housing (more likely if boat inverts). The potential remedies I have seen are; i)Have a snap shackle attatched by shockcord to the rear of the casing to 'anchor' the centerplate downwards, whilst still allowing momement. ii)A small anchor point on the outside of the centreplate case at/around the pivot point, with a safety lanyard attatched, running to the handle with very little slack, preventing the plate dropping out. |
Post Options Quote Reply Posted: 25 Feb 09 at 5:05pm |
This is probably best asked on the Firefly website: like a lot of the class specific things they'll have an answer most folk use that works...
coleyy
Newbie Joined: 23 Feb 09 Location: United Kingdom Online Status: Offline Posts: 10 |
Post Options Quote Reply Posted: 25 Feb 09 at 6:07pm |
or dont capsize it aha
Andymac
Post Options Quote Reply Posted: 26 Feb 09 at 9:25pm |
And they have just upgraded it..... old site; www.fireflysailing.co.uk New site; www.fireflysailing.org.uk It's looking good, and I've managed to register now, since the old site wasn't allowing new forum members because of spam. |
