New Posts New Posts RSS Feed: minisail/laser hybrid
porkyman View Drop Down
Post Options Post Options   Quote porkyman Quote  Post ReplyReply Direct Link To This Post Topic: minisail/laser hybrid
    Posted: 08 Oct 08 at 1:00pm
i have just acquired very cheaply an old minisail, to play with when i`m not on my hobie 17, ( I`m not into racing).   I am wondering if anyone has ever put a laser standard sail on a minisail, as the size is the same (7.4m), and if so, does the laser sail fit onto the minisail mast ?, and if not, can a laser mast be made to fit onto the minisail hull ? As the original minisail sail is shot, and there are so many half decent used laser sails around, i thought this could be a good option to improve the performance of the boat.any suggestions gratefully recieved.
porkyman
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 08 at 1:45pm
As I remember the minisail stick is a fair bit thinner than the Laser one so I doubt a Laser mast would fit. One way to find out for sure though... ... I'm amazed the sails are the same size. I remeber the MS rig as being a good bit smaller.
Medway Maniac View Drop Down
Post Options Post Options   Quote Medway Maniac Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 08 at 2:21pm
I thought of doing this, and decided the best bet would be to use the entire Laser rig, but cut off the bottom of the mast and sleeve in a thick-walled tube of smaller outside diameter which would fit the hole in the Minisail's deck.
You'll need the sliding seat - or maybe better the Moth-style racks favoured by some back in the 70's - for sure.
Let us know how you get on.
www.wilsoniansc.org.uk
www.3000class.org.uk
Iain C View Drop Down
Post Options Post Options   Quote Iain C Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 08 at 2:38pm
Might be better to try a Topper main.
My other half had a minisail for a bit...it was horrible.  Boom was far too bendy too, and the foils were shocking.
49er GBR340
Sabre 27 "Summer Girl"
Foiling Moth GBR4093 "Beermoth"
1963 Flying 15 K797 "Braveheart" (being restored!)
Chew my RS View Drop Down
Post Options Post Options   Quote Chew my RS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 08 at 2:43pm
But the sliding seat makes it all worth while...
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 08 at 4:16pm
The minisailmain is a little larger than the Laser one, but makes the Laser one seem well cut...It has been done before, but I don't know which mast was used. Easy enough to experiment with borrowed kit.
Firefly 2324, Lightning 74, Mirror 67667, Puffin 229, Minisails 3446 & 2427, Topper 44496
minisailnews.blogspot.co.uk
DiverSteve View Drop Down
Post Options Post Options   Quote DiverSteve Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 08 at 4:49pm
I had a Minisail with a full Laser rig for my beach boat.  It was ideal because, along with a Topper, it was the only boat that would fit through a barrier at the end of our road.  It was light blue and sold to a scout group about four years ago.
This was with a Laser mast and boom.
In reasonably light winds it was fine but with such a narrow beam I was grossly overpowered in anything stronger.  I did wonder at the time about mounting boards to be able to hike out further or even fitting trapeze wires but never got further than thinking about it.
Philsy View Drop Down
Post Options Post Options   Quote Philsy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 08 at 5:15pm
Nice idea. I had a MS with a sliding seat as a kid, and have happy memories
of it.
The sail was a basic triangle and the boom too thin with a nasty gooseneck,
so a full Laser rig would
make a lot of sense.
Be interested to read how you get on.
Edited by Philsy
Post Options Post Options   Quote porkyman Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 08 at 7:20pm
many thanks for your comments, i would be particularly interested to hear from `Diversteve`, as to whether there was any adaption required to make the full laser rig fit the minisail, The idea of wings or a s/seat sounds good, although i am not that bothered if it is abit overpowered, adds to the fun!
porkyman
Jamie600 View Drop Down
Post Options Post Options   Quote Jamie600 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 08 at 10:54am
We have a Minisail at our club with a complete Laser rig - sail mast and boom. I didn't take much notice of how it was done but I can have a look next time it's out.
I've also got some old Moth wings if you're interested, PM me!
RS300 332
Bulletin Board Software by Web Wiz Forums® version 9.665x
