New Posts New Posts RSS Feed: 600 mast track
600 mast track
600sailor670 View Drop Down
Post Options Post Options   Quote 600sailor670 Quote  Post ReplyReply Direct Link To This Post Topic: 600 mast track
    Posted: 06 Oct 08 at 7:50pm
Hi everyone,
after this weekends fun and games i now need to glue my mast track (aluminium) back onto the mast (carbon). Anyone know what glue to use?
Any help gratefully appreciated
George
RS600-670
RS600FF - 793
mike ellis View Drop Down
Post Options Post Options   Quote mike ellis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 08 at 8:37pm
which part of it came off? i assume this must be a selden mast (angel ones had the track moulded in as part of the mast).
Also International 14, 1318
Splosh View Drop Down
Post Options Post Options   Quote Splosh Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 08 at 9:17pm
I had the same problem as you earlier in the year.
The glue i used was suplied by LDC with a special glue gun to apply it for about 20 which done the job and is still going strong.
hope this helps,
RS300 - 346 :D
Post Options Post Options   Quote 600sailor670 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 08 at 9:24pm
it popped out of the sail feeder and only pulled up about 30cm from the bottom and it is a super spar,
that glue gun stuff sounds intersting, might look into that, do you know the name?
thanks v much
Edited by 600sailor670
RS600-670
RS600FF - 793
craiggo View Drop Down
Post Options Post Options   Quote craiggo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 08 at 10:30am
PLEXUS
Post Options Post Options   Quote mike ellis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 08 at 8:50pm
make sure you glue it all back down. Try not to miss the bit just under where it pulled off to if you can. It might be worth taking off a big section to glue the whole lot back down properly, unless the rest really wont come off.
