New Posts New Posts RSS Feed: 29er Downhaul block
29er Downhaul block
FireballNeil View Drop Down
Post Options Post Options   Quote FireballNeil Quote  Post ReplyReply Direct Link To This Post Topic: 29er Downhaul block
    Posted: 04 Feb 08 at 12:01pm
The spinny downhaul block on my 29er has a screw that has become loose in the fixing hole- A larger screw has already been put in and thus has worn the hole even more! I know the best option is to refill the hole- drill and secure the block. I just dont know what filler to use. 29ers are polyester if it helps!
Neil
Contender 541 View Drop Down
Post Options Post Options   Quote Contender 541 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 08 at 12:17pm
Novel Idea.....  Try using a polyester based filler
Crew on 505 8780
Post Options Post Options   Quote FireballNeil Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 08 at 12:21pm
Neil
BBSCFaithfull View Drop Down
Post Options Post Options   Quote BBSCFaithfull Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 08 at 8:47pm
Maybe a bit of exoxy with some filler in and apply.
Cheers,
Alex
Greatfully Sponsored By
www.allgoodfun.com
Int 14 GBR 1503!!
