New Posts New Posts RSS Feed: RS600 Mast track
RS600 Mast track
600sailor670 View Drop Down
Post Options Post Options   Quote 600sailor670 Quote  Post ReplyReply Direct Link To This Post Topic: RS600 Mast track
    Posted: 07 Nov 07 at 5:34pm
Hi all,
i have got a RS600 angel mast with a worn mast track near were the track ends at the bottom of the mast, so getting the boltrope to stay in the track whilst raising the main is a pain in the backside. Anyone know of a way to either build it up again or sort it out?
Thanks
George
P.S. mast track is not replaceable and is built on the mast out of carbon.
Edited by 600sailor670
RS600-670
RS600FF - 793
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 07 at 6:32pm
More carbon! What often happens too is that the base of the track splits and so the two sides will force apart more easily.
Make a former out of cardboard and Parcel tape and put it in the track so that you can't get glue and fibre where you shouldn't, and build several layers of carbon over the bottom inch of the track.
Post Options Post Options   Quote 600sailor670 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 07 at 7:27pm
thanks Jim, will try that
 "What often happens too is that the base of the track splits"
that has also happend and quite be quite nasty if it rubs the wrong way on the boltrope . How would you recommend holding the delaminated piece of carbon to the other whilst resin sets? can't really clamp it due to difficult area.
RS600-670
RS600FF - 793
Splosh View Drop Down
Post Options Post Options   Quote Splosh Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 07 at 8:27pm
Don't go adding stuff to it!!!
You can remove the whole/bits of the track off easilly. Buy a new track from LDC its about £8 a metre! If the old track is carbon, LDC supply you with a metal track and special glue which you can easilly join the metal one to carbon one with.
To join them is easy leave about 1/2mm gap and fill with arraldide/epoxy, Then rap some daul (round wood thingy ) wrapped in sand paper and run it up and down the track untill its a smooth join.
I've done this about 2 months back and its all working fine. And it only cost me £30 to replace 3m of track!! It doesnt take too long about 1 week for me to be back on the water!
Its definatly worth taking time over it and doing it properly insead of a rushed messy job!
Splosh.
RS300 - 346 :D
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 07 at 8:29pm
Originally posted by 600sailor670
How would you recommend holding the delaminated piece of†carbon to the other whilst resin sets?
More Parcel tape!!
Post Options Post Options   Quote 600sailor670 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 07 at 8:32pm
thanks all :)
RS600-670
RS600FF - 793
