Laser XD 203301 Upminster |
Laser vs RS Aero for 2024 |
Post Reply | Page 123 11> |
By The Lee
Posting king Joined: 06 Aug 17 Online Status: Offline Posts: 114 |
Topic: Laser vs RS Aero for 2024 Posted: 14 May 19 at 1:35pm |
Which boat do you believe should be selected and why
Post Options Quote Reply Posted: 14 May 19 at 1:38pm | |
No idea.
As I read the evaluation form, the Laser came second primarily because of supply problems and issues with consistency of manufacture, and not because of the boat itself, which scored well on many factors. If the ILCA and new manufacturers got their act together swiftly and sorted out supply and tightened up the tolerances in the construction manual then a rescore would probably put the Laser first. So the results lead to a nasty dilemma: do you vote for the boat that had a better score excluding the supply side, and hope that the current shenanigans will have sorted themselves out by the time the next Olympic cycle starts, or do you vote for the boat that has the better score now, even though that advantage may have vanished by then? Glad I don't have to make that decision! |
By The Lee
Post Options Quote Reply Posted: 14 May 19 at 1:41pm | |
Yes I agree tough decision while I think the Aero is a great boat I believe it would be a disaster for the emerging nations program
Sam.Spoons
Post Options Quote Reply Posted: 14 May 19 at 1:56pm | |
Aero, with the reservation that could RS supply enough boats alongside the increased demand?
Reason? :- From the POV of a grass roots sailor the only benefit the Olympics confers is the raising of the profile of Sailing as a sport. The Lasers an old boat and is showing that age a little these days, the Aero looks much more modern. Sailing is a technology based sport and many of those who might give it a try are likely to be attracted to a more modern boat. Edited by Sam.Spoons - 14 May 19 at 1:57pm |
By The Lee
Post Options Quote Reply Posted: 14 May 19 at 1:59pm | |
But could a non sailor notice the difference?
Sam.Spoons
Post Options Quote Reply Posted: 14 May 19 at 2:14pm | |
Probably not immediately but I think the types who would give sailing/racing a serious try will research a little and be more attracted to the high tech nature of the boat than the 'different virtues' of the Laser.
edit :- I've just read Mark Jardine's article (after I posted that last), pretty much my views too (but much more elegantly worded). Edited by Sam.Spoons - 14 May 19 at 2:20pm |
laser193713
Post Options Quote Reply Posted: 14 May 19 at 3:15pm | |
What I think is strange about the trials is the quality score that the d-zero got. To be less than a third as good as the Aero and roughly a third of the Laser seems a bit of an insult to what I have always thought to be a well put together product. What happened there!? Page 10 of the report if anyone hasn't read it. https://members.sailing.org/tools/documents/EQCSP4biiiMenWomenOnePersonDinghy-%5b24944%5d.pdf
jeffers
Post Options Quote Reply Posted: 14 May 19 at 3:23pm | |
It could still be any of the 4, WS has previous for ignoring the evaluation trials recommendations...
Regards production all 4 boats have the issue in terms of supply/builders and being FRAND compliant. RS and Devoti at least said they would comply with this and appoint builders to ensure supply was met. The current Laser debacle is going to roll on and on not least because WS/ILCA are no inspect the LP factory at the end of the month. I expect the vote will likely be hurry up and wait. As for the comments about build, I am not sure of the source but the D-Zero is pretty robust for a light boat. There were some early production niggles but you get that and the builder sorted them and made tweaks to the production method to mitigate them. |
laser193713
Post Options Quote Reply Posted: 14 May 19 at 3:38pm | |
The source I referred to was the World Sailing report which rated the quality relative to the other boats in the trials, the D-Zero being by far the lowest scoring on quality, which surprised me. How much worse than a Laser can it be!?
jeffers
Post Options Quote Reply Posted: 14 May 19 at 3:44pm | |
Yes and I am unsure as to where they (WS) got their info from as the boat has been pretty robust aside from a few early production niggles which were sorted by the builder as stated above. I would guess they looked at issues vs total boats built so it may be a higher proportion as not as many of them have been built compared to the Laser and Aero.
