New Posts New Posts RSS Feed: Enterprise age?
Enterprise age?
Keifer1972 View Drop Down
Post Options Post Options   Quote Keifer1972 Quote  Post ReplyReply Direct Link To This Post Topic: Enterprise age?
    Posted: 02 Feb 18 at 4:12pm
Hi everyone, i have just bought a Enterprise dinghy made of GRP, can i find out its sge from the numbets on the sail or is there a another way? The only numbers on the sail are E4 in large black print but also im a lower corner is C18105 written in permanant marker, any ideas anybody?
Eisvogel View Drop Down
Post Options Post Options   Quote Eisvogel Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 18 at 4:14pm
It should also be carved on the transom, I think. The sails might not originally belong to the boat.
Enterprise 20361 (Eisvogel), Laser 102727 (Halcyon), Laser 121986 (C U Laser)
Sam.Spoons View Drop Down
Post Options Post Options   Quote Sam.Spoons Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 18 at 4:48pm
The current rules have this to say :-
"The sail number shall be carved in figures not less than 19 mm high in the transom
or may be in the upper face of the aft thwart on moulded and composite boats.
A production serial number shall be engraved on a plate permanently fastened to the inner face of the transom of all boats with moulded hulls."
Not sure how much of that applies to older GRP boats, the number on the makers plate may or may not correspond to the sail number (most likely does on older boats though) but the sail number, if the boat was registered, should be on the hull somewhere.
HTH
Supernova 395 "dolly the sheep"
423zero View Drop Down
Post Options Post Options   Quote 423zero Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 18 at 5:23pm
The "C" number is the measurement certificate number, boat can't be E4, all early boats were wood,
Hull number is burnt into thwart.
jaydub View Drop Down
Post Options Post Options   Quote jaydub Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 18 at 5:27pm
The Mk2 plastic boats, which had wooden thwarts and wooden deck knees, had the sail number carved in the rear thwart.  I'm pretty certain the Holt / Speed FRP boats were the same.   Can't recall where they were in the Mk1 plastic boats and left the class before the new fangled Rondar Mk 3s (and dangly poles for that matter) came into existence.
Post Options Post Options   Quote Eisvogel Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 18 at 8:15pm
If you contact the Enterprise Association, they might be able to tell from the certificate number.
Post Options Post Options   Quote Sam.Spoons Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 18 at 9:05pm
If that certificate belongs to the boat....... But it's definitely worth contacting them, when I had an Ent they were extremely helpful.
Edited by Sam.Spoons - 03 Feb 18 at 9:06pm
transient View Drop Down
Post Options Post Options   Quote transient Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 18 at 5:41pm
Reasonably sure that number is 1975. Worth checking at the class assoc though. Of course if that number is on the sail it probably does not relate to the hull.
Post Options Post Options   Quote 423zero Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 18 at 6:18pm
What year was first plastic boat made, can't be earlier.
E1 and E2, were the first and second Enterprises built and were the two boats that sailed across the channel in the dead of night.
Post Options Post Options   Quote 423zero Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 18 at 6:24pm
http://www.yachtsandyachting.com/news/187239/Brief-history-of-the-Enterprise-Class
