New Posts New Posts RSS Feed: Marina Mooring Depth
Andythefiddler View Drop Down
Post Options Post Options   Quote Andythefiddler Quote  Post ReplyReply Direct Link To This Post Topic: Marina Mooring Depth
    Posted: 04 Sep 17 at 6:19pm
I have a yacht with a draught of 1.68m
I have been offered a mooring which gets down to 1.6 at LAT.
Is there a serious risk here, it's a good mooring at a good price?
The bottom is mud.
I'm about to go through Reeds and see how often we will get that shallow.
Andy
Andy
Tynesider View Drop Down
Online Status: Online
Post Options Post Options   Quote Tynesider Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 17 at 8:38pm
Hi Andy
If the depth is constant then you should not have a problem, however what about neap tides is the depth the same ?, also  if all the  mud is soft then fine but you need to check how soft as it may be just the top few feet.
Mike
      Archivist for the
Colvic Watson Owners Group
PeterG View Drop Down
Post Options Post Options   Quote PeterG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 17 at 9:22am
If it's mud and soft you are unlikely to have any issue.
If it's flat and firm you will hardly notice it - the tide will only get that low for a few hours a year, and 8cm is not a lot! Though lack of access at LW springs might be a consideration.
What you should worry about is what is on the bottom. Exposed mooring blocks or anchors, abandoned sharp objects etc could spoil you day, or at least your keel.
Edited by PeterG - 05 Sep 17 at 9:22am
Peter
Ex Cont 707
Laser 189635
DY 59
