New Posts New Posts RSS Feed: Europe Dinghy Mast Step Repair
Sam.Spoons View Drop Down
Post Options Post Options   Quote Sam.Spoons Quote  Post ReplyReply Direct Link To This Post Topic: Europe Dinghy Mast Step Repair
    Posted: 27 Apr 17 at 11:07am
I'm considering buying an old Europe and have checked it over. All is good apart from the adjustable mast step which is not securely located in the hull. It consists of a sliding ally casting which runs in moulded in rails and locates on an adjuster rod, threaded through the mast pot with a hand wheel in the front buoyancy compartment. (sorry for the long description but I failed to take any pics).
The casting will not come out throughout the hole in the deck (too large) and the deck hole is of a size that I can get my hand through but only get my arm in to mid forearm (not enough to reach the mast step). There are two hatches in the bulkhead and one large one in the deck in front of the mast so access to the mast pot is pretty good but there is no hatch in the mast pot.
I'm guessing I'll have to cut a hole in the mast pot and work through that but before (and if) I buy the boat, does anybody know how the casting is located/secured into the keel and adjuster rod (there is a slot for the rod but no apparent means of stopping it coming off the rod or rails) and how repairs might be effected?
Supernova 395 "dolly the sheep"
Post Options Post Options   Quote Sam.Spoons Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 17 at 10:51pm
Probably irrelevant now but to save anybody taking time to look into this I sailed the Europe over the weekend and decided it wasn't for me (basically, I'm not bendy enough to sail it comfortably around the corners and, if I'm honest with myself, I'm too porky for it....... lovely boat though, if I was a stone or two lighter).
