New Posts New Posts RSS Feed: Enterprise dinghy repairs
nst197 View Drop Down
Post Options Post Options   Quote nst197 Quote  Post ReplyReply Direct Link To This Post Topic: Enterprise dinghy repairs
    Posted: 29 Mar 17 at 1:17am
I've got a relatively recent Ent dinghy, originally built by Glynn Walker, that is in need of some renovation having been sat for a number of years untouched. The main areas of work are going to be replacing: the decks; a section or potentially all of the rear foredeck beam just behind the kingpost; and the outer gunwale rubbing strips.
My questions at this stage are mainly around materials I should be using, does anyone know:
- I'm thinking the deck is 4mm marine ply and I was planing on using Robins tiger-elite to replace it. Does that sound about right?
- What is the foredeck beam likely to be made of?
 - What are the rubbing strips likely to be made of? The current ones are contrasting light colour compared to the decks. From what I've read online I'm thinking Ash is potentially a good bet.
Apologies if I've got some terminology mixed up here but hopefully you can tell what I mean.
Edited by nst197 - 29 Mar 17 at 1:31am
Paramedic View Drop Down
Post Options Post Options   Quote Paramedic Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 17 at 8:19am
Why not ring Glynn at SP boats and ask him? :)
quick google will give you the number
MerlinMags View Drop Down
Admin Group
Admin Group
Post Options Post Options   Quote MerlinMags Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 17 at 10:50am
Pale rubbing strakes? Yes, very likely to be ash.
Structural beams in older boats are likely to be mahogany. Not sure about newer hulls.
Post Options Post Options   Quote nst197 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 17 at 3:36pm
Thanks for the replies folks. I've emailed spboats to see if they can help. Would this boat have come from there originally or is Ent building just something Glynn has done in the past? From looking at the website it doesn't look like they make them anymore if it was from there.
What is interesting is they have a picture on there website of a solo which has identical rubbing strips to my Ent:
http://www.spboats.co.uk/s/cc_images/cache_2456351998.jpg?t=1429983711
Re the structural foredeck beams this is also a light colour compared to the decks so not Mahogany. But I'm not convinced it is the same as the rubbing strips, although it could just be different varnish making it look different.
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 17 at 4:44pm
Sitka spruce is used in boats quite often. Ash, as found in wooden tillers, has a tendency to go black, and while strong (hence the use in tillers) is quite heavy. Also seen maple used.
Post Options Post Options   Quote Paramedic Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 17 at 7:11pm
Glynn Walker was at Don Marine - they went under in the early 00's i believe, a shame they were great craftsmen.
Glynn then did canal boat fit outs for a number of years, and then joined SP boats a few years back. He will remember your boat!
jaydub View Drop Down
Post Options Post Options   Quote jaydub Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 17 at 10:40pm
If your boat is a Walker Enterprise, it was built by Lloyd Walker and not Glynn.
If it is a Don Marine, then it will have been Glynn.
Admin Group
Admin Group
Post Options Post Options   Quote MerlinMags Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 17 at 1:49pm
My pale gunwhales have gone a bit black in places! Is sycamore the other pale wood they might use?
Post Options Post Options   Quote nst197 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 17 at 2:04pm
I've spoken to Glynn just now, really nice chap and couldn't have been more helpful.
The answers for anyone's future reference are:
decks - 6mm tiger ply from Robbins timber
fordeck beam - either Ash or sycamore in my case since it is a light colour. He said he also used mahogany on some boats. Apparently Ash has a strong dark grain and will be rough to the touch. I think mine is Ash.
Gunwale rubbing strips - sycamore with a Brazilian mahogany inlay.
Thanks for all the help folks. Now I've got to decide whether to tackle it myself or send it off to SP boats for Glynn to do it for me .... Ermm
The Moo View Drop Down
Post Options Post Options   Quote The Moo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 17 at 1:29pm
Glynn at SP boats did some deck replacement/repairs to our Ent fairly recently. Very impressed with the workmanship and not as expensive as you might think either. Turnaround was very quick too. Highly recommended
