New Posts New Posts RSS Feed: Hull refinishing
Hull refinishing
Jamie600 View Drop Down
Post Options Post Options   Quote Jamie600 Quote  Post ReplyReply Direct Link To This Post Topic: Hull refinishing
    Posted: 06 Dec 16 at 5:17pm
Has anyone ever had a hull professionally refinished?
By that I mean the gelcoat polished up to look like new, after scratches etc have been repaired?
An idea of rough cost would be good as I want to factor it in to a possible purchase
RS600 810
jeffers View Drop Down
Post Options Post Options   Quote jeffers Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 16 at 6:10pm
If you have a MOP and the scratches have been repaired and smoothed out already then polishing doesn't take too long. I have my Blaze MOP'd after a reapir and it came out at about 150 on top of the repair cost (but bear in mind the boat was already on their bench, it may have been more if it was just in for that).
You can get a reasonably cheap MOP that will do the job for not a lot of money these days so just buying the compounds.
D-Zero GBR188
Ex Rooster 8.1 '11'
Ex Laser 167534
Ex Blaze 655
Sam.Spoons View Drop Down
Post Options Post Options   Quote Sam.Spoons Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 16 at 7:27pm
I bought a car type 'sander/polisher' and some Farecla G3 polishing compound from these guys http://www.cfsnet.co.uk/acatalog/Gelcoat_Polishing.html cost was around 80 all in. My yellow Spice was suffering from the effects of several years use and abuse. Polishing the milkiness from the gel coat was not too hard and while I haven't ended up with showroom condition (will probably do it again in the spring) it does look very much better (it is a 16 year old boat). The Blaze is next for the treatment.......
piglet View Drop Down
Post Options Post Options   Quote piglet Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 16 at 8:19pm
How big is the hull and how scratched is it?
If you close your eyes and drag your finger nails across, anything that your nails pick up won't just polish out.
Papering up through the grades is labour intensive, if they have to be filled then the colour match has to be satisfactory.
IMO a forum price would be pointless, you could be anywhere between a couple of hours and a couple of days.
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 16 at 10:14pm
If a boat costs hundreds, then it has to be diy. If talking thousands, it would be worth talking to someone who does such things professionally to get a quote.
